[AG-TECH] Unable to add services
Thomas D. Uram
turam at mcs.anl.gov
Mon Sep 29 10:43:47 CDT 2003
This sounds like a hostname problem on the machine running the Node
Service. The GLOBUS_HOSTNAME environment variable may be set to a name
that doesn't resolve properly on your network.
If you send the agns.log file from the machine running the Node Service,
and the agsm.log file from your audio machine, I can probably determine
the problem.
Tom
A Quay wrote:
> I’m in the process of upgrading a three CPU node to AG 2.1 and I'm
> receiving errors when adding services via the Node Manager running on
> the display machine:
> Exception in AddService, retrieving service implementation
> -- AccessGrid.DataStore.DownloadFailed Unknown reason
> This is true when adding services to any target machine
> (display,audio,video).
> I also cannot connect to the Service Manager running on the audio
> machine when using the Node Manager. I can ping the machine.
> I’m sure these are simple fixes, thanks,
> andy
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030929/62745cfa/attachment.htm>
