[AG-TECH] Direction of communication with a Virtual Venue Server
Robert Olson
olson at mcs.anl.gov
Fri Sep 26 10:28:47 CDT 2003
At 12:12 AM 9/27/2003 +0900, shudo at ni.aist.go.jp wrote:
>I suppose AGTk 2.x needs establishment of TCP connections initiated by
>a Virtual Venue Server and it is the cause of the problem I'm facing.
>I guess it because the AG node can use a VV server that I run locally
>on the inside of our firewall.
>Is this correct? If so, it's natural that AGTk 2.x do not work in our
>network configuration. And I have to ask our network administrators
>to change the configuration of the firewall.
The AG client should, for all of the basic functionality, make only
outgoing connections. Things that won't work are lead/follow and personal
data on the client behind the firewall.
Are you able to ping the venue server from your machine? Which venue server
were you trying to contact?
--bob
