[AG-TECH] FW: RE: Test Cruise
Michael Daw
mike.daw at man.ac.uk
Wed Sep 17 09:28:48 CDT 2003
Simon's got a problem requesting a certificate. Any ideas? Is there another way he can request a certificate?
-----Original Message-----
Sent: 17 September 2003 15:24
To: Michael Daw
Subject: RE: RE: Test Cruise
Hi Mike,
I've downloaded and installed the access grid software onto my pc (XP) but when I run the "request a certificate" command I get the following error
pythonw.exe - Entry point not Found
The procedure entry point __security_error_handler could not be located in the dynamic link library MSVCR70.dll
Any ideas?
Simon
Sent: 17 September 2003 14:31
To: lee.margetts at man.ac.uk; s.bee at salford.ac.uk
Cc: Kevin.Roy at man.ac.uk
I can do that. As can Kev. Simon's Spanish answer makes me think he can make it. Let's say 10am (BST). See you all in the Virtual Engineering Venue on AG2.x. (Lee - if you need a bridge, you should be able to navigate to this venue and click Preferences/Use unicast and then select a bridge.)
--Mike
> From: lee.margetts at man.ac.uk [mailto:lee.margetts at man.ac.uk]
> Sent: 17 September 2003 11:57
> To: s.bee at salford.ac.uk
> Cc: Kevin.Roy at man.ac.uk; mike.daw at man.ac.uk; lee.margetts at man.ac.uk
> Subject: Re: RE: Test Cruise
> Hi Guys,
> Sorry to be the awkward one! Its an hour ahead here and I
> have Spanish classes after work. Is it possible to arrange
> these tests for the morning??
> Thanks
> Lee
> > Monday is fine with me
> > Simon
> > From: Kevin Roy [mailto:Kevin.Roy at man.ac.uk]
> > Sent: 16 September 2003 15:17
> > To: Michael Daw
> > Cc: s.bee at salford.ac.uk; Lee Margetts
> > Subject: RE: Test Cruise
> > Would everyone be available next monday (22nd) at about
> 3.30 (BST)??
> > Kev.
> > On Tue, 16 Sep 2003, Michael Daw wrote:
> > > Today, we need to sort out a time to have the technical
> test cruise where
> > we make sure we know exactly how the tech's going to work
> (standard SC
> > Global and yours).
> > > > From: S.Bee [mailto:S.Bee at salford.ac.uk]
> > > > Sent: 16 September 2003 10:41
> > > > Hi Mike,
> > > > thanks for the email. I'm afraid I was away last week
> and didn't
> > > > organise the certification for my computer. I'm going
> to run AG
> > > > off my laptop and the CAVE will not need to run access
> grid at
> > > > all, just Hydra, if that makes sense. What do I need
> to do today?
> > > > kind regards,
> > > > Simon
> > > > From: Michael Daw [mailto:mike.daw at man.ac.uk]
> > > > Sent: 15 September 2003 16:25
> > > > Cc: Kevin Roy; Simon Bee
> > > > > Sent: 15 September 2003 16:23
> > > > > To: mike.daw at man.ac.uk
> > > > > Subject: Test Cruise
> > > > > Hi Mike,
> > > > > Suggest any day/time you like (but no earlier than 2
> or 3
> > > > > days from now). I note you didn't copy your email
> to Simon
> > > > > Bee. He's the brains behind what we're going to
> do... and
> > > > > I believe he will be presenting from a cave (in
> Cheddar Gorge?).
> > > > I'll talk to Kev. Simon Bee was on the recipients list
> (this one too!).
> > > > > I bought some cables for the echo canceller.
> Unfortunately,
> > > > > they wont fit because I couldn't get hold of a cable
> with a
> > > > > right-angled jack. Do you think the owner will mind
> if I
> > > > > neatly modify the casing, by cutting out a small
> chunk so
> > > > > that a normal jack may be plugged in?
> > > > Just do it. Whatever works.
> > > > > Cheers
> > > > > Lee
> > | Kevin Roy
> > | Address: CSAR HPC Support
> > | Kilburn Building Telephone: +44 161
> 275 7031 |
> > | University Of Manchester Fax: +44 161
> 275 6800 |
> > | Oxford Road Mobile : +44 7720
> 292 348 |
> > | Manchester
> > | M13 9PL Email:
> Kevin.Roy at man.ac.uk |
> Dr Lee Margetts
> High Performance Computing Consultant
> University of Manchester
> http://www.sve.man.ac.uk/General/Staff/margetts
