[AG-TECH] 2.1.1b Multi-machine Cnfiguration Questions
Rabarison Monika Klara
monika.k.rabarison at ccaix.jsums.edu
Mon Sep 15 15:49:14 CDT 2003
Donell,
I have installed 2.1.1b on 3 machine room node (win 2000 as display,
redhat 7.3 for both audio and video capture, and win 98 for control)
following the "How to Build a Room-based Access Grid Node AGtk 2.0" doc.
1) I did not make any change for the control machine
2) the display machine runs a service manager, the node service, a video
consumer, and the venue client
3) the single capture machine runs a service manager, an audio service,
and 2 video producers (I have 2 cameras)
You may want to recheck your Node Management configuration:
*VideoConsumer on display machine
*Audio Service for Audio Capture
*Video Producers for Video Capture.
I did not add Audio service for the display machine and did not add
VideoConsumer for the video capture machine.
Good Luck,
Monika
On Mon, 15 Sep 2003, Sanders, Donell wrote:
> Ok. I'll try to make this brief. I have installed the 2.1.1b software on
> my Windows and Linux boxes in my four-machine node. I feel like I'm really
> close to a solution with this, but I just can't put my finger on the button,
> if you will. Here's the deal:
> I can log in to the venues via the venue client on my Windows 2K machine
> (the display machine). I can receive video and audio with relative ease (if
> someone's broadcasting audio). I can't seem to send any video or audio
> though.
> I can hear audio on my audio capture machine (RedHat 7.3 Linux) when I run
> the loopback test and the tone test. I can see the meter move in my RAT
> when I click the "Talk" box and tap the microphone.
> I can see video on my video capture machine (RedHat 7.3 Linux) when I run
> the vics attached to the ports given out (after I start the venue client on
> my display machine).
> My display machine venue client is configured with the AudioService and
> VideoConsumer Service enabled for localhost:12000. The four VideoProducer
> Services (one for each camera) and the VideoConsumer Service is configured
> correctly (as far as I can tell) for my video capture machine which is
> called ag-video:12000. The AudioService is configured for ag-audio:12000.
> I don't know what to do about the control machine. It runs the Genter
> software.
> I'm sure there are probably 7,319 places I can check to make sure things are
> where they're supposed to be. I feel like I looked at 7,318 of them.
> Please steer me in the right direction as to what I should check/recheck,
> look/relook, etc. to make sure that everything is connected properly,
> hardware- and software-wise.
> Thanks a lot,
> Donell Sanders
> Winston-Salem State University
Monika Rabarison
Systems Administrator
Office of Information Technology/HPCVI
Jackson State University
Office:(601)979-5933
SciVis Lab:(601)979-1061
JSUvisNode:(601)979-1056
