[AG-TECH] PIG and VideoProducer port
Steve Gallo
smgallo at ccr.buffalo.edu
Thu Sep 11 12:58:57 CDT 2003
Hi Adam,
Even after the patch, i needed to add the full path in for the vic, now
things seem to be working correctly.
Thanks!
Steve
> -----Original Message-----
> From: Adam Quiney [mailto:deathsushi at yahoo.com]
> Sent: Thursday, September 11, 2003 12:31 PM
> To: Steve Gallo
> Subject: Re: [AG-TECH] PIG and VideoProducer port
> Hi Steve,
> I had a similar problem. I believe my video worked
> correctly without specifying a port, but I DID need to
> change the path that was given for the Executable. By
> default, it was set only to "Vic". By providing the
> absolute path to the executable, my VideoProducer
> stream worked.
> --Adam
> --- Steve Gallo <smgallo at ccr.buffalo.edu> wrote:
> > Hello,
> > I've just installed the latest 2.1.1.b software and
> > have noticed that when
> > I look at the Service Config Dialog for my camera
> > (USB web cam) all of the
> > data looks OK, except that the "port" field is blank
> > and the video stream is
> > not coming up.
> > Should there be a value in this field?
> > Steve
> > Steve Gallo
> > AG Node Operator
> > Center for Computational Research
> > University at Buffalo, The State University of New
> > York
> > 9 Norton Hall, Buffalo, NY 14260-1800
> > 716-645-6500 x521
> __________________________________
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site design software
> http://sitebuilder.yahoo.com
