[AG-TECH] AG2.1.1b multi-machine node problems
Ivan R. Judson
judson at mcs.anl.gov
Tue Sep 9 09:19:48 CDT 2003
Hey Chris,
We are actively working on this particular problem to make sure that the
environment is initialized correctly so that in the next release you should
not have the problem of directories existing (or not). Toolkit
initialization will also deal with making sure configurations are in place
and get logging setup in a way that there should be a reduction in the
number of extraneous messages.
The configuration and logging work might not make it into the next bug fix
release, but the directory creation will.
Thanks for you patience, and btw, if you can confirm or deny slackware
functionality we'd be happy to add packages to the web pages (if they're
different from RPMs). Support would obviously be via ag-tech :-)
--Ivan
> -----Original Message-----
> From: Christoph Willing [mailto:chris at vislab.usyd.edu.au]
> Sent: Tuesday, September 09, 2003 2:10 AM
> To: Eric Olson
> Cc: Michael Daw; Ivan R. Judson; 'George Estes'; 'ag Tech'
> Subject: Re: [AG-TECH] AG2.1.1b multi-machine node problems
> Eric Olson wrote:
> >Hi Mike,
> >Ivan and I didn't have any problems the TVS this morning, but let us
> >know
> >if it's still not working for you.
> >And on linux,
> >Thanks for noticing the /tmp/local_services directory. We're moving
> >the
> >local services (cache) to be in the user's
> ~/.AccessGrid/local_services
> >directory, but it looks like it didn't get built into the
> last rpm so
> >we'll get that fixed. Moving it to the user's directory
> will avoid the
> >past problems with the tmp directory.
> I just built a 2.1.1 this morning (Slack 9). The first time I
> ran it, it
> complained about the lack of a ~/.AccessGrid/VenueClient.log (or was
> that VenueServer.log?). I created one by hand, and it ran OK
> after that.
> The point is (I think) that existrence of some locations seems to be
> expected yet there's no mechanism to create them.
> chris
> Chris Willing Telephone (61-2) 9351 3914
> Sydney Vislab, K09
> University of Sydney
> NSW 2006 Australia http://www.vislab.usyd.edu.au
