[AG-TECH] LINUX vs Windows as a AG node Display system
Doug Baggett
dbaggett at nsf.gov
Mon Sep 8 13:13:23 CDT 2003
Sure. That would be great! We are ordering a new AGP 8x motherboard with
the Matrox P750 triplehead card. I don't know about support for XFree86
on the P750, I'l have to check it out. I am hoping that since it's AGP
8x and the mobo is 8x I might get some more performance out of it (more
VIC windows). How do you handle things like DPPT? Just use VNC for linux?
-Doug B
Stephen Bosch wrote:
> Douglas Baggett wrote:
>> Do people on the list have opinions on LINUX vs Windows as a Display
>> system? When AG 1.x came out, linux did not really have that good
>> multi-monitor support. Now that XFree86 has come a ways, I was wondering
>> what people's experience has been with using LINUX as a Display system?
>> I am bit tired of fighting Windows monitor and device drivers for
>> multi-monitor displays (especially when the displays have different
>> resolutions). It seems Windows has a mind of it's own often changing
>> screen placement/order without the user doing anything (mainly in
>> between boots). Other issues include icons/task-bar migrating to
>> different screens when I don't want them to! I'm thinking one advantage
>> of LINUX would be having a set in stone config for XFree86 so that
>> NOTHING changes.
> I would no longer hesitate to suggest using Linux for display systems.
> The multi-head support is much improved, and even if the XFree86
> documentation remains nebulous the XF86Config parameters are much,
> much simpler.
> I'm using a Matrox Parhelia 128 triple-head card. It works like a hot
> damn. The drivers are supposed to be for Redhat, but I've extracted
> them and used them successfully in Slackware. If you need OpenGL
> support Matrox can provide you with beta 3d drivers (those work too).
> I haven't had any of the problems you describe in Linux, although
> there is a bug in the way the Matrox drivers handle the framebuffer
> (logging out of X caused the screen to blank. Not very convenient :) )
> The workaround is simple, though -- just don't use the framebuffer on
> boot. That's mostly eye-candy anyway.
> If you need any help setting up multi-head support in Linux, let me know.
> -Stephen-
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030908/84527c30/attachment.htm>
