[AG-TECH] AG 1.x and Slack
Jacob Jenkins
jmjenki2 at olemiss.edu
Wed Sep 3 13:19:48 CDT 2003
Nevermind. I just switched to a newer (1.4.1) version of Java and
everything works fine. Next time I'll spend more than 10 minutes on a
problem before I mail the list. : )
On Wednesday, September 3, 2003, at 11:50 AM, Jacob Jenkins wrote:
> Does anyone have AG 1.x working in Slack 9? Everything seems to be
> going well except that when I change venues, vrm-eventlistener
> segfaults. It will also segfault when running setup-configure if you
> try to test the camera via the "Test" button.
> If I go to a venue and then start vrm-eventlistener, everything seems
> to work fine.
> The message I get when trying setup-config is:
> /usr/local/ag/bin/setup-config: line 26: 1292 Segmentation fault $JAVA
> ag.SetupConfig $file
> When I change venues while vrm-eventlistener is running I get:
> /usr/local/ag/bin/vrm-eventlistener: line 21: 1314 Segmentation fault
> $JAVA ag.VideoResourceManager --eventURL $EVENT_SERVER_URL --cacheURL
> This is just an annoyance but if anyone has it working without the
> segfaults, I'd be interested in seeing how you did it.
> Thanks,
> Jacob Jenkins
> Network Administrator/Access Grid Node Operator
> Office of Research and Sponsored Programs
> The University of Mississippi
> (662) 915-7482
Jacob Jenkins
(662) 915-7482
