[AG-TECH] AG 1.x and Slack
Jacob Jenkins
jmjenki2 at olemiss.edu
Wed Sep 3 11:50:30 CDT 2003
Does anyone have AG 1.x working in Slack 9? Everything seems to be
going well except that when I change venues, vrm-eventlistener
segfaults. It will also segfault when running setup-configure if you
try to test the camera via the "Test" button.
If I go to a venue and then start vrm-eventlistener, everything seems
to work fine.
The message I get when trying setup-config is:
/usr/local/ag/bin/setup-config: line 26: 1292 Segmentation fault $JAVA
ag.SetupConfig $file
When I change venues while vrm-eventlistener is running I get:
/usr/local/ag/bin/vrm-eventlistener: line 21: 1314 Segmentation fault
$JAVA ag.VideoResourceManager --eventURL $EVENT_SERVER_URL --cacheURL $*
This is just an annoyance but if anyone has it working without the
segfaults, I'd be interested in seeing how you did it.
Jacob Jenkins
Network Administrator/Access Grid Node Operator
Office of Research and Sponsored Programs
The University of Mississippi
(662) 915-7482
