[AG-TECH] RE: **ACE-grid** ACE Collaboration services - A discussion document
John Brooke
John.Brooke at man.ac.uk
Tue Sep 2 04:16:29 CDT 2003
Hi Jason,
These times are fine for Manchester.
On Mon, 1 Sep 2003, Jason Leigh wrote:
> Hi
> In nailing down a date and time for the ACE collab services AG meeting,
> we tentatively had Sept 10, 11, 12.
> John Brooke indicated that Sept 10 would be bad.
> I can do Sept 11 but not till 1pm Central time.
> 1pm Central
> 2pm East Coast
> 7pm in England
> 8pm in Germany
> Otherwise we can try for Sept 17 at 11am Central time.
> Any suggestions welcome. If I don't hear anything I'll assume Sept 11 at
> 1pm is fine for everyone. :>
> Jason
> Jason Leigh, PhD
> Associate Professor, Computer Science Department
> spiff at evl.uic.edu Electronic Visualization Lab (M/C 152)
> EVL Phone (312) 996-3002 University of Illinois at Chicago
> EVL FAX (312) 413-7585 851 S. Morgan St. Room 1120 SEO
> http://www.evl.uic.edu/spiff Chicago, IL 60607-7053
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Brian Corrie
> > Sent: Wednesday, August 27, 2003 12:08 PM
> > To: Ace; ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] RE: **ACE-grid** ACE Collaboration
> > Hello all,
> > As Jason has said (see email below), we are organizing an AG
> > meeting to
> > discuss ACE collaboration services, why they are important,
> > and how they
> > should be described. This is a continutation of the "ACE collaboration
> > services" discussion that we had at GGF in Seattle. As a
> > point of discussion,
> > here is a brief position statement from my point of view...
> > This is based on
> > the GGF discussion from Seattle (powerpoint provided).
> > http://calder.ncsa.uiuc.edu/ACE-grid/2003-06-24_GGF8/GGF8-corrie.ppt
> > We are planning on having a meeting either September 10, 11,
> > or 12. Please
> > let us know if you are interested in participating and if so which
> > dates/times are best.
> > I have cross posted this to the ag-tech mailing list as I
> > think there will be
> > people there that are interested in this area that may not be
> > on the ACE
> > list...
> > >From our point of view, providing a succesful collaboration
> > requires a number
> > of steps. One has to:
> > 1) Understand the collaboration task being undertaken
> > 2) Understand the needs required to accomplish the task
> > 3) Determine the collaboration services required to meet those needs
> > 4) Determine how to deliver those services most effectively
> > on the technology
> > available to the user.
> > My goal in moving this discussion forward is to define what
> > we mean by a
> > collaboration service so that we can perform the mapping from
> > needs (2 above)
> > to services (3 above) to technologies (4 above).
> > To accomplish the mapping from need to service the services
> > have to be well
> > defined. They should be standards based and not application based if
> > possible. We need to be able to identify what services meet
> > the needs of the
> > collaboration task and be able to combine them in a very
> > flexible manner to
> > accomplish that task. That means that services need to work
> > together to
> > accomplish an overall goal that can be quite complex. To
> > determine how to do
> > that one needs to know alot about the "capabilities" of the
> > services. It is
> > probably necessary to classify services into groups that
> > satisfy a given need
> > (classes might be audio, video, shared presentation,
> > application sharing,
> > floor control, turn taking, visualization, ...). For example,
> > a specific
> > collaboration task may NEED audio, video, and shared
> > presentation. There may
> > be a number of services that provide a solution for each need. Vic,
> > netmeeting, realvideo, and quicktime all satisfy the need to
> > have video. The
> > NEED has certain requirements (interactive video) and
> > services have certain
> > capabilities (vic is interactive, realvideo is not). If one
> > knows the needs
> > of the task and the capabilities of the services we can map
> > from need to
> > service to come up with a set of services that satisfy the needs of a
> > collaboration (vic satisfies the interactive video need while
> > realvideo does
> > not). Thus far we are talking at an abstract level that is focused on
> > accomplishing the task at hand as succesfully as possible. We
> > call this
> > "Quality of Experience" or QoE.
> > Once a set of services is identified for a task, we need to map those
> > services onto a set of technologies to actually deliver the
> > collaboration. To
> > do this, we need to know both the resources required for the
> > services and the
> > capabilities of the devices that the services are going to be
> > running on.
> > Running vic at 256Kb/s h261 codec requires 256kb/s bandwidth
> > per video stream
> > and 50%CPU + 10% per video stream (I know, % CPU is not the
> > best metric in
> > the world 8-). Machine A is connected to the other
> > collaborators over the
> > research network at 10 Mbps and has a video capture
> > capability. If we know
> > this information for each service in a collaboration and each
> > machine being
> > used we can make intelligent aggregate decisions at the task
> > level about what
> > machines should run which services and more importantly when
> > and how the
> > system should compromise on specific needs to make the
> > collaboration as high
> > quality as possible (degrade the video quality rather than
> > have poor audio in
> > the collaboration).
> > To perform any of these mappings it is critical to define what a
> > collaboration service is and what its capabilities and
> > attributes are. More
> > importantly, if we can describe service capabilities in a well defined
> > manner, then a true service model can be built in which
> > services can be used
> > across multiple systems but decisions can be made about the
> > collaboration
> > task at the task level.
> > So what are the questions we need to ask (from the powerpoint)?
> > How do we classify collaboration services (or do we need to)?
> > How do we describe collaboration services?
> > - What class of service is it?
> > - What are its capabilities (what can it do)?
> > - How does it do it (protocols, standards)?
> > - What does it require (memory, bandwidth, CPU)?
> > How do we register collaboration services (registration and
> > discovery)?
> > How do we instantiate services (service creation)?
> > That is our view of collaboration services and how they
> > I hope that it is relatively clear. I would welcome any
> > discussion on this
> > topic and I hope to see some of you at the AG meeting next month...
> > Cheers,
> > Brian
> > > From: Jason Leigh [mailto:spiff at evl.uic.edu]
> > > Sent: Wednesday, August 13, 2003 5:37 PM
> > > To: 'Ace'
> > > Subject: RE: **ACE-grid** ACE Collaboration services
> > > Looks like there is a conflict with the AG2 tutorial. How
> > > about Sept 10,
> > > 11 or 12?
> > > Jason
> > > Jason Leigh, PhD
> > (M/C 152)
> > > > From: owner-ace-grid at gridforum.org
> > > > [mailto:owner-ace-grid at gridforum.org] On Behalf Of Jason Leigh
> > > > Sent: Wednesday, August 13, 2003 3:19 PM
> > > > To: Ace
> > > > Subject: **ACE-grid** ACE Collaboration services
> > > > Hi
> > > > Brian and I are planning to hold an AG meeting to elaborate on ACE
> > > > collaboration services that was discussed at GGF8. For those
> > > > interested,
> > > > please indicate your prefered dates for the meeting: Sept 3
> > > or 4 or 5.
> > > > Here are notes from the last discussion:
> ie.ppt
> > > Thanks
> > > Jason
> > > Jason Leigh, PhD
> > (M/C 152)
