[AG-TECH] Loading a certificate on video machine?
Susanne Lefvert
lefvert at mcs.anl.gov
Fri Oct 31 10:34:39 CST 2003
Mike,
A good check to see if your certificate is imported/loaded properly is to
start the Venue Client and connect to a venue from the machine where you
want to use the AGServiceManager. If that works, the AGServiceManger
should be able to use that certificate too. Else, you have to import the
certificate; from the Venue Client menu select 'Preferences - Import
Identity Certificate' and choose certificate files (usercert and userkey)
(or select 'Import Default Globus Certificate', if you have a Globus
certificate).
Susanne
On Fri, 31 Oct 2003, Michael Daw wrote:
> How do I 'load' a certificate on my video machine?
> When I run AGServiceManager.py, I get the message 'Cannot use globus
> communications because no certificate is loaded' (or something like that).
> I have a certificate on that machine and I can do a grid-proxy-init, so what
> else do I need to do to make it work?
> --Mike
> _______________________________________________________
> Michael Daw, e-Science Consultant
> SVE Group (Supercomputing, Visualization and e-Science)
> Manchester Computing, Kilburn Building,
> University of Manchester, Manchester M13 9PL, UK
> Tel: +44 (0)161 275 7026
> Fax: +44 (0)161 275 6800
> E-mail: michael.daw at man.ac.uk
> http://www.sve.man.ac.uk/General/Staff/daw
