[AG-TECH] its friday.........and we failed.....
Colin Perkins
csp at csperkins.org
Fri Oct 31 07:51:59 CST 2003
On Friday, Oct 31, 2003, at 02:54 Europe/London, Richard Naylor wrote:
> Now where I need help is that of the 4 AG set ups, rat only seems to
> work on 2. All machines are winXP and rat seems to start, but there is
> no gui window (it appears in the task list). this is the same for both
> the AG rat and the mbone tools rat. Any ideas ?
Rat uses host-local multicast as an inter-process communication
mechanism between the user-interface and media engine. If you see the
media engine running but not the UI, it's almost certainly a problem
with the local multicast.
Check your local firewall (UDP port 47000) or multicast routing table.
Colin Perkins
http://csperkins.org/
