[AG-TECH] Shared Presentation?
Thomas D. Uram
turam at mcs.anl.gov
Thu Oct 30 12:29:31 CST 2003
Randy:
To use SharedPresentation:
- Add SharedPresentation to the venue
- Join the SharedPresentation instance you just added (or one that
existed previously)
- Click the "Take control as master" checkbox
- Enter the URL to a set of slides in the Slides field, and press enter
That should start the slide show locally.
If you join a session that has slides already specified, the slide show
should begin at the current slide for the app session.
Let me know if this doesn't work for you.
Tom
And, you're right, you still can't change the name of application
instances in the venue.
Randy Groves wrote:
> (Still curious if anyone's gotten this to work ...)
> Anybody gotten the new Shared Presentation to work?
> There isn't any way that I can see to point to a presentation before
> starting up the Shared Presentation application. And once it fires
> up, I get a blank Powerpoint window and a dialog box asking for
> 'Slides' and the slide number. So far, I haven't figured out the
> magic incantation that I'm supposed to enter to make the connection
> between what looks to be the control dialog and the Powerpoint window.
> Anybody got any hints?
> (And it's still not possible to change the title from 'Shared
> Presentation' to anything else).
> -randy
