[AG-TECH] AG2 Configuration
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Oct 22 14:18:55 CDT 2003
Hi Eliot:
Of the three problems you reported:
-  In that version, AGServiceManager.py printed extraneous text; it
doesn't indicate any error
-  You need to run the SetupVideo.py script as root
-  You need to create the /tmp/local_services directory on the machine
to which you are adding services.
I'd suggest you get version 2.1.2 that was released yesterday.  This
will eliminate the third problem you had, and provide you with
NodeSetupWizard.py.  The setup wizard will perform most of the steps
outlined in the RoomNode howto document, simplifying the configuration
of your node.
If you have any questions, please ask.
Tom
Eliot Feibush wrote:
> Hello,
> I am trying to configure our node for AG 2.0.  I'm going through the
> steps in the document "How to Build a Room-Based Access Grid Node."
> When I try to start the Service Manager on the video machine I get:
> $ python /usr/bin/AGServiceManager.py
> Video resources file not found; run SetupVideo.py
> Found id certs
> [<AccessGrid.CertificateRepository.CertificateDescriptor instance at
> 0x83e9854>]
> Default ident
> 0x83e99f4>]
> CA cert /C=US/O=Globus/CN=Globus Certification Authority:
> hash=42864e48 dest=/home/ag/.AccessGrid/trustedCACerts/42864e48.0
> CA cert /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
> Developers CA: hash=45cc9e80
> dest=/home/ag/.AccessGrid/trustedCACerts/45cc9e80.0
> done, success= 1
> AGServiceManager URL:  https://agvideo-tst.pppl.gov:12000/ServiceManager
> When I try to run SetupVideo.py I get:
> $ python /usr/bin/SetupVideo.py
> Traceback (most recent call last):
>   File "/usr/bin/SetupVideo.py", line 46, in ?
>     f = open( tclScriptFile, "w" )
> IOError: [Errno 13] Permission denied: 'tclScript'
> And if I try to run NodeManagement on the video machine and add a
> Service I get:
> $ python /usr/bin/NodeManagement.py
> Found id certs
> 0x873415c>]
> Default ident
> 0x87edd84>]
> Invalid Node Service URI: https://localhost:11000/NodeService
> Exception in AddService :
> AccessGrid.hosting.pyGlobus.AGGSISOAP.faultType <Fault
> exceptions.Exception: Exception: Error adding service: Exception:
> AGServiceManager.AddService failed: [Errno 2] No such file or
> directory: '/tmp/local_services/VideoProducerService.zip'>
> How do I take care of these errors?
> Also, is there any other documentation for installing and configuring
> AG2?
> Thank you.
> Eliot Feibush
