[AG-TECH] Problems getting started with AG2.1
Robert Olson
olson at mcs.anl.gov
Wed Oct 22 13:46:11 CDT 2003
For those who aren't paying close attention, the following is a fix for a
problem involving trusted CA certificates whose filenames begin with 0.
At 05:23 PM 10/22/2003 +0100, pns at soc.soton.ac.uk wrote:
>As I mentioned, the signing policy was absent from
>../AccessGrid/trustedCACerts, so I copied it over again.
>On starting up the venue client, I got the same problem as before.
>When I looked at the files in the trustedCACerts dir, I find that the
>01621954_signing_policy file has disappeared, and the CA cert filename has
>now lost it's leading zero to become 1621954.0
The problem here is in pyOpenSSL, one of the packages that supports the
AGTk certificate management code. I've placed a fixed pyOpenSSL installer at
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/releases/2.1.2/windows/pyOpenSSL-2003-1022.exe
(aka http://snurl.com/elh for now anyway).
The MD5 checksum:
32ae04b8244759d9a14a6216ab157f91 pyOpenSSL-2003-1022.exe
To install this, first ensure that your venue client is not running (the
install will fail due to files being in use).
Download the aforementioned file and execute it. It'll prompt for a python
version, which in most cases should be correct. Answer "Yes" to the
question about overwriting files. When it completes, start your venue
client again. It will regenerate the trusted CA certs directory with the
proper filenames. Mine now looks something like this:
10/22/2003 01:40 PM <DIR> ..
10/22/2003 01:40 PM 1,786 01621954.0
10/22/2003 01:40 PM 626 01621954.signing_policy
10/22/2003 01:40 PM 820 42864e48.0
10/22/2003 01:40 PM 1,362 42864e48.signing_policy
10/22/2003 01:40 PM 920 45cc9e80.0
10/22/2003 01:40 PM 1,367 45cc9e80.signing_policy
6 File(s) 6,881 bytes
Please let me know if you have any questions or problems with this.
