[AG-TECH] encryption, vic and rat
Michael Miller
mimiller at ncsa.uiuc.edu
Tue Oct 14 07:42:10 CDT 2003
Jason,
I'm not sure what the problem was earlier in the day with other nodes not
hearing/seeing you.
But later in the day you are correct, by connecting to the NCSA Test
VenueServer, your vic and RAT received encryption keys. When I set up the
venues, I'm almost positive that I turned off encryption on all the venues,
perhaps I missed one. I can't tell because when I attempt to modify a
venue, I'm getting a seg fault.
This configuration was created with the v2.1.1 software and I'm now running
v2.1.2-beta. So there may be some backwards compatibility issues.
I have filed the appropriate bug reports...
Michael Miller
NCSA
At 05:43 PM 10/13/2003, Jason Hill wrote:
>I had an interesting problem arise today and was wondering if anyone
>had some input to answer some questions I have.
>We're running 2.1.1 and were running vic and rat by hand for a meeting on
>the NCSA venue server. We could see all the remote sites and could hear
>all the remote audio, but no one could hear or see us. I was not the node
>operator for this portion of the meeting, so this is what I was told when
>I arrived for the afternoon session.
>Later when I was directed to the NCSA 2.1.1 Venue server I could only see
>my streams - but there was an encryption set in Vic and Rat. Once removed
>I could see all the other streams and hear all the audio. Are these
>encryptions set by the venue server? Are they set upon entry into the venue?
>I don't know all of what happened when vic and rat were started up by hand
>- but I think that they too were set with encryption - not by the user.
>Are there differences between the vic that was released with 2.0 and with
>2.1.1? Has anyone seen this before?
>Thanks,
>-Jason
>Jason Hill
>jahill at scl.ameslab.gov
>Scalable Computing Laboratory, Ames Laboratory
>310 Wilhelm Hall
>Ames, IA 50010
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
