[AG-TECH] Hauppage WinTV USB cards
Adam Quiney
adam_quiney at yahoo.com
Tue Nov 25 12:47:33 CST 2003
Sorry,
I should have mentioned that the reason our machine
can only accomodate one PCI Hauppage card is because
the machine has one PCI slot and a bunch of PCI-X
slots, which apparently will not fit the Hauppage
cards. I'm hoping that I can solve this problem by
using one PCI capture card and two USB cards, but
would like to double check and make sure this is
feasible.
--Adam
--- "Carter, Tameka" <ttcarter at bnl.gov> wrote:
> I don't know about the USB capture cards, but I
> usually make the video
> producer open three VIC windows to use our three
> Hauppauge cards. When an
> error shows up, I am then able to select the other
> cards. It seems to be an
> okay workaround for the card's incompatibility.
> -----Original Message-----
> From: Adam Quiney [mailto:adam_quiney at yahoo.com]
> Sent: Tuesday, November 25, 2003 12:38 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Hauppage WinTV USB cards
> Hi everyone,
> Has anyone had any experience using the Hauppage
> WinTV
> USB capture cards with an AG setup? We received one
> our computers today only to discover that we can
> only
> accomodate one of the cards (oops), and are now
> looking to the USB cards as an alternative.
> Cheers,
> --Adam
> __________________________________
> Do you Yahoo!?
> Free Pop-Up Blocker - Get it now
> http://companion.yahoo.com/
Do you Yahoo!?
