[AG-TECH] AG 2.1 Error Message
Singletary, Abraham
SINGLETARYA at MAIL.ECU.EDU
Tue Nov 4 07:37:52 CST 2003
Can anyone give me some assistance with this?
The computer network configuration is not correct. To correct the problem,
"by setting the Globus_Hostname environment variable" and restart the app.
Application will exit "Globus_Hostname is configured, but is not set in the
process. If you started this program from a command window, you may have to
start a new command window to run with the proper setting."
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20031104/ba2cea20/attachment.htm>
