[AG-TECH] grid-proxy-init Segfaulting on Debian
Ti Leggett
leggett at mcs.anl.gov
Fri May 30 06:10:16 CDT 2003
My suggestion is that if you want to make debian packages you should
grab the rpm spec file and make the equivalent debian file to build the
debs from the ground up. If you read through the spec files there's all
the info you need on how to get globus configured, compiled, and
installed. If you're not familiar with rpm spec file format, I have a
document in CVS at doc/AG-RPM-Build-HOWTO.doc that should get you
started. Good luck!
On Thu, 2003-05-29 at 18:15, Jason wrote:
> So far we've gotten the setup-gsi to configure and recieved a
> certificate. I began (with the install instructions on the web) with
> executing the grid-proxy-init and found that there was not a link to the
> libglobus_ssl_utils_gcc32pthr.so.0, (as well as some other packages that
> were required to continiue)so I added the path of the shared object file
> to /etc/ld.so.conf and went out and got the remaining packages.
> Now there's a segmentation fault error. My earlier post mentioned the
> UNIX install instructions and Ti pointed out that there were more steps
> in the execution that needed to be run. Is this the case again?
> Does anyone know if this could be a problem between the way that RedHat
> packages stuff or if the C library module is different between RH and
> Debian? That would possibly mean that for a Debian install we would need
> to get the source and re-compile with the Debian C library and then
> begin the install - which isn't a big deal.
> I checked out the CVS tonight and there's lots of good info on getting
> the AG software configured, but not much on the configuration of the
> Globus packages.
> Thanks again for the help.
> -Jason
> Jason Hill
> jahill at scl.ameslab.gov
> Ames Laboratory, SCL
> 310 Wilhelm Hall
> Ames, IA 50010
