[AG-TECH] Ag2.0 Install on Debian Linux
Ti Leggett
leggett at mcs.anl.gov
Thu May 29 09:02:07 CDT 2003
On Wed, 2003-05-28 at 20:48, Jason wrote:
> I'm working on trying to install the Ag2.0 software on Debian and have
> tried to use the rpm's and even gone as far as using alien to convert
> the rmps to debian packages.
> Using the instructions at
> http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid I get errors.
> The problem I have run into either way is that the setup-gsi script is
> failing while executing grid-security-config. The grid-security.config
> file is created just fine, but there is some problem I can't resolve
> when it configures. The script is bailing out at line 133 of
> /usr/lib/globus/setup/globus/setup-gsi.pl if that helps anyone who may
> offer a response.
There's several commands you need to run after installing Globus to get
it setup. First and foremost you must have gpt installed. After that you
should be able to do the following:
. /etc/profile.d/gpt.sh
. /etc/profile.d/globus.sh
${GPT_LOCATION}/sbin/gpt_verify
${GPT_LOCATION}/sbin/gpt-postinstall
/usr/lib/globus/setup/globus_simple_ca_45cc9e80_setup/setup-gsi -default
> My question is this: Can I install from the CVS source and where would
> information about installing from the CVS source be located? I have all
> the prerequisite software that is available in debian packages
> (Python2.2, libwxgtk2.2, libwxgtk2.2-python, python logging) installed
> and it appears to be ready, but the error above has me stuck in my tracks.
> Thanks,
> Jason Hill
> jahill at scl.ameslab.gov
> Ames Laboratory, SCL
> 310 Wilhelm Hall
> Ames, IA 50010
