[AG-TECH] errors during installation
Feng
fjh at sdb.ac.cn
Fri May 23 22:41:17 CDT 2003
Ti Leggett
About the first Error, I think perhaps it was caused by python.Which version have you installed.
I met the same error with you during installation under redhat 7.2.But after change the OS to redhat 8.0
everything seems run smoothly.
Good luck!
Feng
fjh at sdb.ac.cn
2003-05-24
R&D Dept.
Computer Network Info Center,Chinese Academy of Sciences
Tel: 0086-10-62536760
Fax: 0086-10-62560928
Email:fjh at cnic.ac.cn
======= 2003-05-14 12:24:00 Wrote :=======
>On Wed, 2003-05-14 at 11:27, Cindy Sievers wrote:
>> OK, I'm installing the 2.0 on my multiple machine node as per Tom's
>> instructions (thank you Tom!!!)....I installed prerequisites and 2.0 on the
>> windows machine (Display machine, w2K) Everything seems to install
>> fine. Now on the audio machine (linux 2.4.18-3) I get through all the
>> prerequisites (and I have no clue what the heck all those are - do I need
>> to install all 9 of them?) and they all install fine. I install the
>> AccessGrid rpm from the web site and get this error:
>> >[root at agaudio2 ag2]# rpm -ivh AccessGrid-2.0RC-1.i386.rpm
>> >Preparing... ########################################### [100]
>> >groupadd: group ag exists
>> >useradd: user ag exists
>> >error: execution of pre scriptlet from AccessGrid-2.0RC-1 failed, exit
>> >status 9error: install: pre scriptlet failed (2), skipping
>> >AccessGrid-2.0RC-1
>Hmm.. I thought I had fixed that. I'll see if I can get that fixed. Just
>out of curiosity, what previous version of the AGTk were you running on
>that machine? You should be able to give rpm the --force option to go
>ahead and install the new package:
>rpm --force AccessGrid-2.0-RC1.i386.rpm
>> I am root when I do the installation - does that matter?
>> Also, the document says for the audio machine, install the Server Manager -
>> I don't see that on the software page. Maybe it is called something else,
>> or it is automatically installed with the AccessGrid rpm.....I don't know.....
>> I'm sure I'll have more questions, but for now, I'm stuck......
>> Thanks for your help!
>> Cindy
>> Cindy Sievers Los Alamos National Laboratory
>> sievers at lanl.gov Group CCS-1 MS B287
>> tel:505.665.6602 Advanced Computing
>> fax:505.665.4939 Los Alamos, NM 87544
