[AG-TECH] AG 2.0 questions
Thomas Uram
turam at mcs.anl.gov
Wed May 21 23:12:55 CDT 2003
Feng:
One thing for sure is that you don't have permission to access your
video devices, according to the output.log you sent:
V4l: trying /dev/video0... open: Permission denied
V4l: trying /dev/video1... open: Permission denied
V4l: trying /dev/video2... open: Permission denied
V4l: trying /dev/video3... open: Permission denied
This would explain why you're not seeing video.
As for vic crashing, an earlier ag-vic rpm did crash when transmitting
video. You should try installing the current ag-vic rpm to see if it
fixes the crash.
Tom
Feng wrote:
>Thomas Uram
> I have try the connection again, please see the details information below.
> After running the AGServiceManager.py in Audio machine and Video machine,I startup the venue client and do the node management .In the video Service manager,I only create two VidoeProducerServices to test.It seems everything work well till now.
> I press the "Go" button to connect the default venue server.I check my Audio and Video machine.The rat run well automatically in Audio machine,It does work.The video machine pop up two video capture window,though there is no image apears,It seems that the vic have startuped properly.And my display machine ,the VideoConsumer service produce two black video window in vic,of course these two videos come from my video machine.
> I check Video machine .After one or two minutes,the vic of Video machine closed ,I do nothing at all to it.
>There are some Error messages print on the command terminal.I have saved it as output.log.please check the output.log and
>AGService.log of the attachment of this mail.
> Can you help me ,Please? Thanks for all.
>Best Regards.
> Feng
> fjh at sdb.ac.cn
> 2003-05-22
>R&D Dept.
>Computer Network Info Center,Chinese Academy of Sciences
>Tel: 0086-10-62536760
>Fax: 0086-10-62560928
>Email:fjh at cnic.ac.cn
>======= 2003-05-21 11:37:00 :=======
>>Hi Feng:
>>We'll need more information to understand the issue you are seeing with
>>the VideoProducerService. If the problem occurs reliably, describe it in
>>more detail. By "shutdown", do you mean it stops sending video? Or that
>>the VideoProducerService process dies? This additional information,
>>possibly with logfiles (AGService.log and others) will help us identify
>>the problem.
>>As for the blue/green video issue, you should check that the parameters
>>in vic are set appropriately for your video card. Blue video can result
>>from inappropriate choices for the port (S-video, composite, etc.), and
>>green video can result from inappropriate choices for the signal (PAL,
>>NTSC,etc.)
>>Tom Uram
>>Feng wrote:
>>>Hi,
>>> I have installed my AG 2.0.the Audio and video machine use Redhat 8.0,the Node Service and Display is install under WindowXP,after I configure the Node with node manager.I run my
>>>venue client to connect,but it does not run smoothly.I have four video capture cards,so I add four VideoProduceService,but sometimes one service shutdown without any interference.And the other three videos is not display properly.It is in full blue or green color.
>>> Any help is highly appreciated.thanks a lot.
>>> Jiahong ,Feng
>>> fjh at sdb.ac.cn
>>> 2003-05-21
>>>R&D Dept.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030521/20186221/attachment.htm>
