[AG-TECH] AG 2.0 questions
Feng
fjh at sdb.ac.cn
Wed May 21 21:12:43 CDT 2003
Dear Thomas Uram,
Sorry ,I have forgot the attachment.:)
Please check it.thanks .
Feng
fjh at sdb.ac.cn
2003-05-22
R&D Dept.
Computer Network Info Center,Chinese Academy of Sciences
Tel: 0086-10-62536760
Fax: 0086-10-62560928
Email:fjh at cnic.ac.cn
======= 2003-05-21 11:37:00:=======
>Hi Feng:
>We'll need more information to understand the issue you are seeing with
>the VideoProducerService. If the problem occurs reliably, describe it in
>more detail. By "shutdown", do you mean it stops sending video? Or that
>the VideoProducerService process dies? This additional information,
>possibly with logfiles (AGService.log and others) will help us identify
>the problem.
>As for the blue/green video issue, you should check that the parameters
>in vic are set appropriately for your video card. Blue video can result
>from inappropriate choices for the port (S-video, composite, etc.), and
>green video can result from inappropriate choices for the signal (PAL,
>NTSC,etc.)
>Tom Uram
>Feng wrote:
>>Hi,
>> I have installed my AG 2.0.the Audio and video machine use Redhat 8.0,the Node Service and Display is install under WindowXP,after I configure the Node with node manager.I run my
>>venue client to connect,but it does not run smoothly.I have four video capture cards,so I add four VideoProduceService,but sometimes one service shutdown without any interference.And the other three videos is not display properly.It is in full blue or green color.
>> Any help is highly appreciated.thanks a lot.
>> Jiahong ,Feng
>> fjh at sdb.ac.cn
>> 2003-05-21
>>R&D Dept.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030522/7ae1767a/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030522/7ae1767a/attachment-0001.obj>
