[AG-TECH] AG 2.0 questions
Thomas Uram
turam at mcs.anl.gov
Wed May 21 11:37:03 CDT 2003
Hi Feng:
We'll need more information to understand the issue you are seeing with
the VideoProducerService. If the problem occurs reliably, describe it in
more detail. By "shutdown", do you mean it stops sending video? Or that
the VideoProducerService process dies? This additional information,
possibly with logfiles (AGService.log and others) will help us identify
the problem.
As for the blue/green video issue, you should check that the parameters
in vic are set appropriately for your video card. Blue video can result
from inappropriate choices for the port (S-video, composite, etc.), and
green video can result from inappropriate choices for the signal (PAL,
NTSC,etc.)
Tom Uram
Feng wrote:
>Hi,
> I have installed my AG 2.0.the Audio and video machine use Redhat 8.0,the Node Service and Display is install under WindowXP,after I configure the Node with node manager.I run my
>venue client to connect,but it does not run smoothly.I have four video capture cards,so I add four VideoProduceService,but sometimes one service shutdown without any interference.And the other three videos is not display properly.It is in full blue or green color.
> Any help is highly appreciated.thanks a lot.
> Jiahong ,Feng
> fjh at sdb.ac.cn
> 2003-05-21
>R&D Dept.
>Computer Network Info Center,Chinese Academy of Sciences
>Tel: 0086-10-62536760
>Fax: 0086-10-62560928
>Email:fjh at cnic.ac.cn
