[AG-TECH] After starting VenueClient.py ??
Thomas Uram
turam at mcs.anl.gov
Thu May 15 15:13:07 CDT 2003
Nikhil:
Can you provide more info about how it fails? Include a description of
the failure and log files from the install directory. If the logs are
big, you can send them just to me, and not to all of ag-tech.
Tom
nikhil wrote:
>Hi,
>I am in the venue "https://vv2.mcs.anl.gov:9000/Venues/default". I see myself
>and other participants listed under Participants. Now i select MyNode->Manage
>which pops up another window. Then i select File->Attach_to_Node and enter
>the hostname of my machine. Then when i want to add service from a pop down
>menu, it fails ??
>Thanks,
>Nikhil
>PS: By the way I am also able to run the same s/w on my previous RH 7.0
>machine.
>On Thursday 15 May 2003 06:58 pm, Jennifer Teig von Hoffman wrote:
>>Hi Nikhil,
>>You might be looking at an outdated set of instructions, assuming you've
>>installed Release Candidate 1; please try:
>> http://scv.bu.edu/~jtvh/AGTk2/rc1.txt
>>When the venues client opens, you should click "Go".
>>- Jennifer
>>nikhil wrote:
>>>Hi,
>>>After installing the complete AG s/w on my RH 7.3 machine, I started
>>>VenueClient.py. It opens up a window and the URL shown is :
>>>https://vv2.mcs.anl.gov:9000/Venues/default.
>>>But on top it displays "You are not in a Venue". Then i select
>>>MyNode->Manage (as per instructions given on a web page link) which pops
>>>up another window. Now what ? How do i connect to a venue and start
>>>communicating ? I browsed thru the online documentation but found no
>>>instructions to go step-by-step. Thanks for your help.
>>>Nikhil
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030515/f413384b/attachment.htm>
