[AG-TECH] Python package not getting installed ??
Ivan R. Judson
judson at mcs.anl.gov
Wed May 14 16:24:01 CDT 2003
Hey,
That's a missing prerequisite, pyIPC. This isn't needed after RC1, but to
use RC1 you have to install pyIPC on linux. RPMS available from our software
prereqs page.
--Ivan
> -----Original Message-----
> From: nikhil [mailto:nikhil at east.isi.edu]
> Sent: Wednesday, May 14, 2003 12:20 PM
> To: judson at mcs.anl.gov; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Python package not getting installed ??
> Hi Ivan,
> You are right, I will try on 7.3. But before i do that, could
> you tell me what
> the following error relates to:
> [ag at schizophrenia agnode]$ AGNodeService.py
> Traceback (most recent call last):
> File "/usr/bin/AGNodeService.py", line 24, in ?
> from AccessGrid import PersonalNode
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/PersonalNode.py",
> line 24, in ?
> from AccessGrid import PersonalNodeLinux
> File
> "/usr/lib/python2.2/site-packages/AccessGrid/PersonalNodeLinux.py",
> line 30, in ?
> import pyipc
> ImportError: No module named pyipc
> Could it be the issue between RH 7.0 and 7.3 ??
> Thanks a lot for your patience.
> Nikhil
> On Wednesday 14 May 2003 09:09 pm, Ivan R. Judson wrote:
> > Nikhil,
> > You really want to try and install on RH 7.3, there are a
> lot of buggy
> > issues trying to install on < 7.3.
> > Would you consider upgrading? It'll make your life easier,
> and ours.
> > Just ask Dave Semararro :-)
> > --Ivan
> > > From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov]
> > > On Behalf Of nikhil
> > > Sent: Wednesday, May 14, 2003 12:08 PM
> > > To: ag-tech at mcs.anl.gov
> > > Subject: [AG-TECH] Python package not getting installed ??
> > > Thanks, this problem is solved by X server access control
> (xhost +)
> > > But the next issue is that when I was querying 'rpm -q
> python', it
> > > was showing the old version of pyhton even though I have
> installed
> > > all the python packages. Then I removed the old package, so that
> > > 'rpm -q python' does not
> > > show any such package installed. I reinstalled the python
> > > RPMs, still no
> > > luck, still it shows no such package installed ??
> > > Nikhil
> > > On Wednesday 14 May 2003 03:13 pm, nikhil wrote:
> > > > Hi,
> > > > After installling complete s/w on my Linux RH 7.0, I
> incur problem
> > > > while running AGNodeService.py, as :
> > > > [ag at schizophrenia root]$ AGNodeService.py &
> > > > [1] 2777
> > > > [ag at schizophrenia root]$ Xlib: connection to ":0.0" refused
> > > by server
> > > > Xlib: Client is not authorized to connect to Server
> > > > Gtk-WARNING **: cannot open display: :0.0
> > > > [1]+ Exit 1 AGNodeService.py
> > > > Seems a problem with accessing, right ??
> > > > Thanks,
> > > > Nikhil
> > > Computer Networks Division
> > > USC Information Sciences Institute
> > > Arlington, VA 22203
> Arlington, VA 22203
