[AG-TECH] Python package not getting installed ??
nikhil
nikhil at east.isi.edu
Wed May 14 12:19:59 CDT 2003
Hi Ivan,
You are right, I will try on 7.3. But before i do that, could you tell me what
the following error relates to:
[ag at schizophrenia agnode]$ AGNodeService.py
Traceback (most recent call last):
File "/usr/bin/AGNodeService.py", line 24, in ?
from AccessGrid import PersonalNode
File "/usr/lib/python2.2/site-packages/AccessGrid/PersonalNode.py",
line 24, in ?
from AccessGrid import PersonalNodeLinux
File
"/usr/lib/python2.2/site-packages/AccessGrid/PersonalNodeLinux.py",
line 30, in ?
import pyipc
ImportError: No module named pyipc
Could it be the issue between RH 7.0 and 7.3 ??
Thanks a lot for your patience.
Nikhil
On Wednesday 14 May 2003 09:09 pm, Ivan R. Judson wrote:
> Nikhil,
> You really want to try and install on RH 7.3, there are a lot of buggy
> issues trying to install on < 7.3.
> Would you consider upgrading? It'll make your life easier, and ours. Just
> ask Dave Semararro :-)
> --Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of nikhil
> > Sent: Wednesday, May 14, 2003 12:08 PM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] Python package not getting installed ??
> > Thanks, this problem is solved by X server access control (xhost +) !
> > But the next issue is that when I was querying 'rpm -q
> > python', it was showing
> > the old version of pyhton even though I have installed all the python
> > packages. Then I removed the old package, so that 'rpm -q
> > python' does not
> > show any such package installed. I reinstalled the python
> > RPMs, still no
> > luck, still it shows no such package installed ??
> > Nikhil
> > On Wednesday 14 May 2003 03:13 pm, nikhil wrote:
> > > Hi,
> > > After installling complete s/w on my Linux RH 7.0, I incur problem
> > > while running AGNodeService.py, as :
> > > [ag at schizophrenia root]$ AGNodeService.py &
> > > [1] 2777
> > > [ag at schizophrenia root]$ Xlib: connection to ":0.0" refused
> > by server
> > > Xlib: Client is not authorized to connect to Server
> > > Gtk-WARNING **: cannot open display: :0.0
> > > [1]+ Exit 1 AGNodeService.py
> > > Seems a problem with accessing, right ??
> > > Thanks,
> > > Nikhil
> > Computer Networks Division
> > USC Information Sciences Institute
> > Arlington, VA 22203
Arlington, VA 22203
