[AG-TECH] Problem while installing python2.2 on Linux (RH 7.0)
Ti Leggett
leggett at mcs.anl.gov
Tue May 13 16:23:08 CDT 2003
expat-devel should be on the install media you installed Red Hat from or
also from ftp://ftp.redhat.com/redhat/linux/7.0/en/os/RedHat/RPMS if I
recall correctly.
Also, by "installing Source RPMS" you do mean building RPMs from the
srpm right? In case you're not sure how to, here's how as root:
rpm --rebuild <source rpm file>
On Tue, 2003-05-13 at 16:18, Nikhil Mittal wrote:
> Hi,
> I am installing Source RPMS python-2.2 on RH 7.0. I get error "failed
> dependency : expat-devel needed" ??
> Where do i get it from ?
> Thanks,
> Nikhil
