[AG-TECH] unable to run PIG successfully
Justin Binns
binns at mcs.anl.gov
Mon May 12 11:44:22 CDT 2003
Robert,
It looks like what's happening is that more than one Event Manager
is being run. This is likely caused by double-clicking more than once on
the 'Start PIG' icon, or by not killing off all the 'javaw' processes when
you log-out.
On another note, I'd suggest you give 2.0 a shot. It's a very
different beast, and we've got regular walk-throughs and assistance on
getting it going on Tuesdays. It'll be easier to make it work, and easier
to debug, most likely ;-)
Justin
On Mon, 12 May 2003, Davies, Robert wrote:
> I am at the Army Research Lab and we have consistently been having problems
> getting the PIG to operate consistently. The problems we're encountering
> are occurring on two different computers.
> To briefly run down the problems:
> It has worked, with both video and audio, for version 1.2, at times.
> In those cases when it works, though, as soon as I log off, or restart, or
> really do pretty much anything, it stops working. To get it working again,
> I basically need to do a full reinstall of the software. Not only that, but
> I need to do a clean wipe of all files related to Access Grid, and the only
> way I've found that this works is by uninstalling, then reinstalling the
> previous version (1.1), then uninstalling that, then reinstalling version
> 1.2. Just doing a straight uninstall/reinstall of 1.2 is insufficient cause
> it leaves some (registry?) files in there. When I've done all this, it
> works. But as soon as it starts going wrong, I need to go through this
> whole process to get it functioning again.
> At other times, like today, going through this process is insufficient. I
> am unable to get versions 1.1 or 1.2 working right now.
> The problem is basically that the Event Server Monitor pops up, and seems to
> get stuck either on "Configuring" or "Stopped". Neither the audio nor
> display resource managers show a heartbeat.
> Also, running version 1.1, the DOS window pops up with the following
> exception:
> "Exception in thread "main" org.omg.CORBA.COMM_FAILURE:
> java.net.BindException: Address in use
> at com.ooc.OCI.IIOP.impl.Acceptor.,init.(Acceptor.java:303)
> at com.ooc.CORBA.BOA.set_parameters(BOA.java:598)
> at com.ooc.CORBA.ORB.BOA_init(ORB.java:738)
> at ag.CorbaApp.initCorba(CorbaApp.java:41)
> at ag.EventServerMonitor.<init>(EventServerMonitor.java:208)
> at ag.EventServerMonitor.main(EventServerMonitor.java:190)
> Any insights/solutions to these problems would be appreciated.
> Thank you,
> Robert Davies
