[AG-TECH] 2.0 install
George Estes
gestes at ncsa.uiuc.edu
Wed May 7 13:54:30 CDT 2003
That did it, thanks.
George
At 01:04 PM 5/7/2003 -0500, Ti Leggett wrote:
>This I'm not sure, but I recall that someone else here had an error
>similar and that's what it was. Oh and I just remembered. After sourcing
>the proper files you have to run:
>$GPT_LOCATION/sbin/gpt-postinstall
>$GPT_LOCATION/sbin/gpt_verify
>All these steps should be printed out after you install the globus rpm.
>I'll double check to make sure they are.
>On Wed, 2003-05-07 at 12:58, Frank Sweetser wrote:
> > On Wed, May 07, 2003 at 12:56:11PM -0500, Ti Leggett wrote:
> > > You must first source in the proper globus config files
> > > export GPT_LOCATION=/usr/lib/gpt
> > > export GLOBUS_LOCATION=/usr/lib/globus
> > > . $GLOBUS_LOCATION/etc/globus/globus-user-env.sh
> > Won't the script error out earlier of those config files haven't been
> sourced?
