[AG-TECH] Invalid host info error
rohn at selway.umt.edu
Fri Mar 28 18:06:15 CST 2003
Here I am replying to my own message. I should have added that when the
initial vic tool comes up, it has not "followed" the display machine to
the initial venue -- i.e., the "address," "port," and "ttl" boxes are all
empty. I can manually enter the address/port/ttl into these boxes and the
captures start (I noticed I can also enter the display machine's IP and
the port 10001 and a capture starts???).
Any insight would be welcome.
Rohn
> Howdy all,
> Having a bit or trouble in the final stages of trying to get our AGN
> room running.
> I followed the procedures as documented in Gary's document:
> http://www.accessgrid.org/agdp/guide/building-an-access-grid-node.html
> and I do not believe I missed anything.
> (*) I ran setup-config on the video machine.
> (*) I ran set-display-machine on both the video and audio machines. (*)
> I registered my computers with our DNS admins and updated the
> /etc/hosts files on all 3 machines (display, video, audio).
> I ran the ag-audio-agtest and ag-video-agtest and determined that I
> appeared to be sending audio and video.
> Specifically, after these bits of configuration and testing, I follow
> the procedure outlined in: "How to Start up an Access Grid Node Using
> Virtual Venues" --
> I start the display computer and see the "Event Server Monitor" window
> (with a stus: ready indicated) and the "Display Resource Manager" (with
> HeartBeat and Connected showing positive). I launch the Venues and I am
> connected to the Access Grid Lobby.
> My problem occurs on starting the audio and video machine. The errors I
> see are slightly different different in terms of the output. I will
> pare it down to the salient details:
> After starting vrm-evenlistner on the video machine, I see this (once
> for each camera):
> Start capture
> Invalid host info
> followed by java output (which I read elsewhere were more informational
> than error) that I can send if needed.
> and on the audio machine, after staring the arm-eventlisterner, I see
> this:
> Invalid host info: java.lang.NumberFormatException:
> Got ANY type 16
> again followed by java output similar to those on the video machine.
> Any ideas on what I missed?
> Thanks!
> Rohn Wood
> University of Montana
> Details of my setup follow,
> I have the 3 main boxes:
> Display: Windows 2000 Service Pak 3
> AGN Software: version 1.2
> Audio:Linux RedHat 7.3, kernel-smp-2.4.18-3
> AGN Software: I used the update script located at:
> http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS/update
> I know this script was indicated as being for a RedHat 7.1 installation,
> but I had no errors during installation. I had to go with Linux 7.3 in
> order to get support for the Video subsytem in the PCs I was given.
> Video:Linux RedHat 7.3, kernel-smp-2.4.18-3
> ditto above
