[AG-TECH] PAL vs NTSC
jzeeff at internet2.edu
Sat Mar 15 18:18:06 CST 2003
PAL is better resolution but if you use the poor quality H.261 codec,
I doubt it will help.
Quoting Andrew Daviel <andrew at andrew.triumf.ca>:
> On Wed, 19 Feb 2003, Osland, CD (Chris) wrote:
> > I know it's really bad form to reply to your own mailing, but I
> OK IMO if you discover new facts or find the answer ...
> > As I've mentioned in another thread, we're interested in higher
> > resolution video streams - PAL for starters, XGA would also be
> > nice - and these will presumably require CPU power, presumably
> > in proportion to the area (in pixels). Therefore, with the
> > current video streams being about 110K pixels and requiring
> > about 1400/20 = 70 MHz, PAL streams (768x576 = 440K pixels
> I wondered if there was any advantage in feeding a bT878 card from
> a PAL camera as against an NTSC one when using Vic.
> The data sheet for the Sony EVI-D100/D100P says 768 x 494 effective
> pixels for NTSC and 752 x 582 for PAL.
> Probably more trouble than it's worth for us here in North America
> regards
> Andrew Daviel, TRIUMF, Canada
> Tel. +1 (604) 222-7376
> security at triumf.ca
