[AG-TECH] PAL vs NTSC
Andrew Daviel
andrew at andrew.triumf.ca
Sat Mar 15 12:12:39 CST 2003
On Wed, 19 Feb 2003, Osland, CD (Chris) wrote:
> I know it's really bad form to reply to your own mailing, but I
OK IMO if you discover new facts or find the answer ...
> As I've mentioned in another thread, we're interested in higher
> resolution video streams - PAL for starters, XGA would also be
> nice - and these will presumably require CPU power, presumably
> in proportion to the area (in pixels). Therefore, with the
> current video streams being about 110K pixels and requiring
> about 1400/20 = 70 MHz, PAL streams (768x576 = 440K pixels
I wondered if there was any advantage in feeding a bT878 card from
a PAL camera as against an NTSC one when using Vic.
The data sheet for the Sony EVI-D100/D100P says 768 x 494 effective
pixels for NTSC and 752 x 582 for PAL.
Probably more trouble than it's worth for us here in North America
regards
Andrew Daviel, TRIUMF, Canada
Tel. +1 (604) 222-7376
security at triumf.ca
