[AG-TECH] Re: [APAG] Help installing ag software
Sugree Phatanapherom
g4465027 at ku.ac.th
Tue Mar 11 02:05:21 CST 2003
Before starting any programs, please change directory to
/usr/share/AccessGrid
----- Original Message -----
To: "Sugree Phatanapherom" <g4465027 at ku.ac.th>; <ag-tech at mcs.anl.gov>
Sent: Tuesday, March 11, 2003 2:13 AM
Subject: Re: [AG-TECH] Re: [APAG] Help installing ag software
> Did you find a solution to this problem? I'm getting the same error.
> George
> At 05:22 PM 3/4/2003 +0700, Sugree Phatanapherom wrote:
> >Envelope-From: owner-ag-tech at mcs.anl.gov
> >From: "Sugree Phatanapherom" <g4465027 at ku.ac.th>
> >To: "Jason Bell" <j.bell at cqu.edu.au>, <ag-tech at mcs.anl.gov>,
> > <apag at prg.cpe.ku.ac.th>
> >Cc: <chris at vislab.usyd.edu.au>, <Dominique.Morel at jcu.edu.au>,
> > <m.barry at qut.edu.au>
> >Subject: [AG-TECH] Re: [APAG] Help installing ag software
> >Date: Tue, 4 Mar 2003 17:22:38 +0700
> >X-Mailer: Microsoft Outlook Express 6.00.2800.1106
> >X-Spam-Level: *
> >X-Spam-Status: No, hits=1.5 required=5.0
> >tests=FROM_ENDS_IN_NUMS,PORN_14,WEIRD_PORT version=2.21
> >X-Spam-Level: *
> >Sender: owner-ag-tech at mcs.anl.gov
> >X-MD5SUM: add6114a31e574b7227f101c50aa9f32
> >Hi,
> >In my opinion, you should try both AG 1.0 and AGtk 2.0 to keep track of
the
> >development. I wrote a brief step-by-step installation guide for later
use.
> >You may be interesting to read it as a guide-line.
> >http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid
> >Anyway, I got errors while trying to add services. Service Manager should
> >find AudioService in local_services but it didn't find. Then, it tried to
> >load the service online but again it read on wrong directory. The correct
> >value might be services/AudioService.zip. I guess that Service Manager is
> >confusing the use of local_services and services.
> >===> cut here <===
> >Retrieving Service Package:
> >https://prg-34-13.cpe.ku.ac.th:62556/packages/AudioService.zip
> >Exception in AddService, retrieving service implementation
> >-- exceptions.IOError [Errno 2] No such file or directory:
> >'local_services/AudioService.zip'
> >*** Method AddService exception ****************************************
> >Traceback (most recent call last):
> > File
>"/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py"
> >line 3839, in do_POST
> > fr = apply(f, args, {'_SOAPContext':c})
> > File
> >"/usr/lib/python2.2/site-packages/AccessGrid/hosting/AccessControl.py",
line
> >285, in __call__
> > raise fault
> >faultType: <Fault : <Fault AGServiceManager.AddService failed: [Errno 2]
No
> >such file or directory: 'local_services/AudioService.zip': >>
