[AG-TECH] Re: [APAG] Help installing ag software
George Estes
gestes at ncsa.uiuc.edu
Mon Mar 10 13:13:40 CST 2003
Did you find a solution to this problem? I'm getting the same error.
George
At 05:22 PM 3/4/2003 +0700, Sugree Phatanapherom wrote:
>Envelope-From: owner-ag-tech at mcs.anl.gov
>From: "Sugree Phatanapherom" <g4465027 at ku.ac.th>
>To: "Jason Bell" <j.bell at cqu.edu.au>, <ag-tech at mcs.anl.gov>,
> <apag at prg.cpe.ku.ac.th>
>Cc: <chris at vislab.usyd.edu.au>, <Dominique.Morel at jcu.edu.au>,
> <m.barry at qut.edu.au>
>Subject: [AG-TECH] Re: [APAG] Help installing ag software
>Date: Tue, 4 Mar 2003 17:22:38 +0700
>X-Mailer: Microsoft Outlook Express 6.00.2800.1106
>X-Spam-Level: *
>X-Spam-Status: No, hits=1.5 required=5.0
>tests=FROM_ENDS_IN_NUMS,PORN_14,WEIRD_PORT version=2.21
>X-Spam-Level: *
>Sender: owner-ag-tech at mcs.anl.gov
>X-MD5SUM: add6114a31e574b7227f101c50aa9f32
>Hi,
>In my opinion, you should try both AG 1.0 and AGtk 2.0 to keep track of the
>development. I wrote a brief step-by-step installation guide for later use.
>You may be interesting to read it as a guide-line.
>http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid
>Anyway, I got errors while trying to add services. Service Manager should
>find AudioService in local_services but it didn't find. Then, it tried to
>load the service online but again it read on wrong directory. The correct
>value might be services/AudioService.zip. I guess that Service Manager is
>confusing the use of local_services and services.
>===> cut here <===
>Retrieving Service Package:
>https://prg-34-13.cpe.ku.ac.th:62556/packages/AudioService.zip
>Exception in AddService, retrieving service implementation
>-- exceptions.IOError [Errno 2] No such file or directory:
>'local_services/AudioService.zip'
>*** Method AddService exception ****************************************
>Traceback (most recent call last):
> File
>"/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py",
>line 3839, in do_POST
> fr = apply(f, args, {'_SOAPContext':c})
> File
>"/usr/lib/python2.2/site-packages/AccessGrid/hosting/AccessControl.py", line
>285, in __call__
> raise fault
>faultType: <Fault : <Fault AGServiceManager.AddService failed: [Errno 2] No
>such file or directory: 'local_services/AudioService.zip': >>
