[AG-TECH] Pal cameras
Michael Daw
mike.daw at man.ac.uk
Wed Mar 5 03:16:26 CST 2003
Rest assured this *does* work as advertised, and what's more, you should be
able to set PAL as the default option in setup-config. If there isn't an
option to do this, then you have an old version of the setup-config software
and I can probably point you to a newer version.
--Mike
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Allan Spale
> Sent: 04 March 2003 18:50
> To: Jason Wood
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Pal cameras
> Jason,
> After pressing the Menu button on the VIC window, a configuration window
> will appear. There is a button on the left side that says Signal. When I
> pressed the button, you could select the following: auto, NTSC, PAL,
> SECAM. I have never tried this, so I do not know if this will work
> exactly "as advertised".
> Allan
> EVL at UIC
> node-op
> On Tue, 4 Mar 2003, Jason Wood wrote:
> > Is there an option to vic to get it to select PAL as the video format
> > by default rather than NTSC? We have a mixture of cameras so I need to
> > be able to set them on a per video board basis, but this I can
> do as long
> > as I can then change the default.
> > jason
