[AG-TECH] Pal cameras
Allan Spale
aspale at evl.uic.edu
Tue Mar 4 12:49:32 CST 2003
Jason,
After pressing the Menu button on the VIC window, a configuration window
will appear. There is a button on the left side that says Signal. When I
pressed the button, you could select the following: auto, NTSC, PAL,
SECAM. I have never tried this, so I do not know if this will work
exactly "as advertised".
Allan
EVL at UIC
node-op
On Tue, 4 Mar 2003, Jason Wood wrote:
> Is there an option to vic to get it to select PAL as the video format
> by default rather than NTSC? We have a mixture of cameras so I need to
> be able to set them on a per video board basis, but this I can do as long
> as I can then change the default.
> jason
