[AG-TECH] Pal cameras
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Wed Mar 5 03:10:07 CST 2003
Jason,
I'm puzzled - if you can change it, why is the default important,
other than reducing the number of sessions you have to change, if
you have something like a 3 PAL, 1 NTSC split?
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Jason Wood [mailto:jason at comp.leeds.ac.uk]
Sent: 04 March 2003 16:50
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Pal cameras
Is there an option to vic to get it to select PAL as the video format
by default rather than NTSC? We have a mixture of cameras so I need to
be able to set them on a per video board basis, but this I can do as long
as I can then change the default.
jason
