[AG-TECH] multi machine AG2.0
    Thomas Uram
    turam at mcs.anl.gov
    Tue Jun 24 16:13:52 CDT 2003
AG2 writes temporary files into the /tmp/local_services directory.  The
problem, in this case, was that the directory did not exist (copying the
zip files there was actually not necessary).
This reliance is already planned to go away.
Tom
George Estes wrote:
> Frank, you nailed it.  Replaced local_services directory and moved
> .zip file to /tmp/local_services and it works again.  Not sure why
> AG2.0 is using /tmp?
> At 01:27 PM 6/24/2003 -0400, you wrote:
>> On Tue, Jun 24, 2003 at 11:32:58AM -0500, George Estes wrote:
>> >     I'm running AG2.0 on three machines.  When I attempt to add a
>> service
>> > to the audio or video machine I get this error:
>> > Exception: Error adding service: Exception:
>> AGServiceManager.AddService
>> > failed: [Errno 2} No such file or directory:
>> > '/tmp/local_service/VideoProducerService.zip'
>> >     Anyone else have this problem?
>> Does the directory /tmp/local_service/ and the corresponding zip
>> files exist?
>> If not, then did you install the VideoProducer rpm?  And if so,
>> perhaps they
>> got cleaned out by a /tmp scrubber.
>> BTW, is there any good reason why the AG rpms keep important files in
>> /tmp?
>> Frank Sweetser fs at wpi.edu
>> WPI Network Engineer
