[AG-TECH] grid-proxy-init
    Coorpender, Steven
    SCoorp at LSUHSC.EDU
    Thu Jun 19 11:49:34 CDT 2003
I am trying to install the AGTk2.0 on 2 machines--one win2K and one
linux---I have the linux box up and running with videoProducer and audio
services, but I am having problems with the win2K machine which will run
VideoConsumer services.
After installing the prereq software, I copied the userkey.pem and
usercert.pem from my working linux machine to the appropriate directory on
the win2k machine, then ran the globus configuration with no errors. I then
installed the AgTk2.0 and ran grid-init-proxy. I click create and then get a
message box with the following errors:
1584:error:0906D06C:PEM routines:PEM_read_bio:no start
line:.\crypto\pem\pem_lib.c:662:Expecting:CERTIFICATE
1584:error:80069072:lib(128):proxy_init_cred:processing
cert:.\gssapi_ssleay\sslutils.c:2515:File=C:\Documents and
Settings\Administrator\Application Data\globus\usercert.pem
Does anyone have any suggestions as to what I could try next? Do I need to
copy any other files from the linux machine (s.a. Globus CA certificate and
the signing policy)? Thanks.
Steven Coorpender
Systems Analyst
LSU Eye Center, New Orleans, LA
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030619/06ef54b8/attachment.htm>
