[AG-TECH] running Venue client
Ti Leggett
leggett at mcs.anl.gov
Mon Jun 16 11:23:04 CDT 2003
Send the output from the following two commands:
rpm -qa | grep AccessGrid
echo $PATH
On Mon, 2003-06-16 at 09:56, Vandana wrote:
> Below is the output.
> [vandana at portavideo ~]$ grid-proxy-init
> Your identity: /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=ccs.uky.edu/CN=vandana
> Enter GRID pass phrase for this identity:
> Creating proxy
> Done
> Your proxy is valid until Mon Jun 16 23:59:50 2003
> [vandana at portavideo ~]$ AGNodeService.py
> AGNodeService.py: Command not found.
> Thanks
> Vandana
> On 16 Jun 2003, Ti Leggett wrote:
> > Can you paste the full output from the console window you're running it
> > from. i.e., include all the commands your entered and they're output.
> > On Mon, 2003-06-16 at 09:23, Vandana wrote:
> > > Hi,
> > > After running grid-proxy-init when I run AGNodeService.py for
> > > venue client. It says command not found.
> > > Any suggestions.
> > > Thanks,
> > > Vandana
