[AG-TECH] running Venue client
Vandana
vandana at ccs.uky.edu
Mon Jun 16 09:56:08 CDT 2003
Below is the output.
[vandana at portavideo ~]$ grid-proxy-init
Your identity: /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=ccs.uky.edu/CN=vandana
Enter GRID pass phrase for this identity:
Creating proxy
Done
Your proxy is valid until Mon Jun 16 23:59:50 2003
[vandana at portavideo ~]$ AGNodeService.py
AGNodeService.py: Command not found.
Thanks
Vandana
On 16 Jun 2003, Ti Leggett wrote:
> Can you paste the full output from the console window you're running it
> from. i.e., include all the commands your entered and they're output.
> On Mon, 2003-06-16 at 09:23, Vandana wrote:
> > Hi,
> > After running grid-proxy-init when I run AGNodeService.py for
> > venue client. It says command not found.
> > Any suggestions.
> > Thanks,
> > Vandana
*******************Catch Me If You Can At*******************
Vandana Ganeshdas Chopra
Research Assistant
315 McVey Hall Home Address:
Center for Computational Sciences, 700 Woodland Avenue
University of Kentucky, Apt. #E107
Lexington, KY 40506-0045 Lexington, KY 40508
Ph: 859-257-8739 Ph:859-323-2635
