[AG-TECH] Quick bridge
    Ti Leggett
    leggett at mcs.anl.gov
    Fri Jun 13 16:39:03 CDT 2003
I'm not sure you could do it behind NAT. Well at least not having
multiple video producers on the same machine or even a video producer
and consumer on the same machine. I think because UDP is stateless, and
the video connections all connect to the same port and ip there's no way
to NAT it.
But I defer to those more knowledgeable.
On Fri, 2003-06-13 at 16:19, Bob Riddle wrote:
> any advice on getting Quickbridge (mTunnel) working behind a firewall
> and a NAT?
> Ti Leggett wrote:
> > If you could get the machine out from behind the firewall that would be
> > ideal, but if you can't and this is a temporary situation, then you can
> > use the QuickBridge. If it's not temporary, I'd really push for getting
> > it out from the firewall and if you still can't, then you should sign up
> > for the multi session bridge.
> > But I digress...
> > In order to use the QuickBridge, the person/site starting it needs to
> > know the Venue your trying to connect to. Currently the only real
> > supported/unsupported venues are on the TVS. If you're trying to connect
> > to someone else's VenueServer you'll have a harder time because of the
> > dynamic multicast and such.
> > After the person has started the QuickBridge, you'd need to turn off all
> > AudioServices, and VideoProducers/Consumers and start rat and vic (one
> > for each camera and one for your display) giving them the appropriate
> > ip/ports.
> > Hope that helps!
> > On Fri, 2003-06-13 at 14:25, Praveen Chandramohan wrote:
> > > hi,
> > >   I've got AG 2.0 set up in a computer in ORNL that is behind a
> > > firewall. This would lead to multicast problems.
> > >   Is anyone familiar with setting up a Quick Bridge, so that i can use
> > > it to multicast? I would appreciate if you could guide me through the
> > > procedures for AG 2.0.
> > > thanks,
> > > Praveen.
> Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
> 3025 Boardwalk, Suite 100         Ann Arbor, Michigan  48108
> Business Phone: 734.913.4257      Fax Number:  734.913.4255
> "Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
