[AG-TECH] Quick bridge
    Bob Riddle
    bdr at internet2.edu
    Fri Jun 13 16:19:13 CDT 2003
any advice on getting Quickbridge (mTunnel) working behind a firewall
and a NAT?
Ti Leggett wrote:
>If you could get the machine out from behind the firewall that would be
>ideal, but if you can't and this is a temporary situation, then you can
>use the QuickBridge. If it's not temporary, I'd really push for getting
>it out from the firewall and if you still can't, then you should sign up
>for the multi session bridge.
>But I digress...
>In order to use the QuickBridge, the person/site starting it needs to
>know the Venue your trying to connect to. Currently the only real
>supported/unsupported venues are on the TVS. If you're trying to connect
>to someone else's VenueServer you'll have a harder time because of the
>dynamic multicast and such.
>After the person has started the QuickBridge, you'd need to turn off all
>AudioServices, and VideoProducers/Consumers and start rat and vic (one
>for each camera and one for your display) giving them the appropriate
>ip/ports.
>Hope that helps!
>On Fri, 2003-06-13 at 14:25, Praveen Chandramohan wrote:
>>hi,
>>  I've got AG 2.0 set up in a computer in ORNL that is behind a
>>firewall. This would lead to multicast problems.
>>  Is anyone familiar with setting up a Quick Bridge, so that i can use
>>it to multicast? I would appreciate if you could guide me through the
>>procedures for AG 2.0.
>>thanks,
>>Praveen.
Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
3025 Boardwalk, Suite 100         Ann Arbor, Michigan  48108
Business Phone: 734.913.4257      Fax Number:  734.913.4255
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030613/06a28ea9/attachment.htm>
