[AG-TECH] Local AGTk2.0 VenueServer Problem.
Thomas Uram
turam at mcs.anl.gov
Fri Jun 6 16:08:52 CDT 2003
Andrew:
Try removing VenueServer.cfg. This file stores the configuration of the
venue server. Therein is an option for the default venue, which appears
not to exist. The venue doesn't exist, so no Enter method is found.
(Yes, the error should say that the URL is invalid, not that the method
is not found.)
If that doesn't fix the problem, let me know.
Tom
Andrew Bolyea wrote:
>I had setup an AG2RC1 VenueServer a few weeks ago, and
>everything worked very well. My AG2RC1 VenueClient could
>connect to it without any problems.
>Today I wiped my VenueServer clean, and installed the new
>AG2.0 VenueServer. Now I can't connect to it anymore. I
>am using the new AG2.0 VenueClient as well. I have no
>problems connecting to the default VenueServer (vv2.mcs...)
>Any ideas? Any help would be appreciated.
>Thanks,
>Andrew.
>Here is the VenueClient.log:
>06/06/03 16:26:57 608 AG.Types venueclient.py:649 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://oa-ag-venue.sheridanc.on.ca:8000/VenueServer
>06/06/03 16:26:57 608 AG.CertificateManager certificatemanager.py:1146 DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=sheridanc.on.ca/CN=ag/CN=proxy
>06/06/03 16:26:57 608 AG.CertificateManager certificatemanager.py:363 DEBUG Proxy C:\DOCUME~1\AG\LOCALS~1\Temp\proxy is valid
>06/06/03 16:26:57 608 AG.Types venueclient.py:856 DEBUG Set history url: None
>06/06/03 16:26:57 608 AG.Types venueclient.py:775 ERROR bin.VenueClient::EnterVenue failed
>Traceback (most recent call last):
> File "VenueClient.py", line 676, in EnterVenue
> warningString = VenueClient.EnterVenue( self, URL )
> File "C:\Python22\Lib\site-packages\AccessGrid\VenueClient.py", line 264, in EnterVenue
> (venueState, self.privateId, streamDescList ) = Client.Handle( URL ).get_proxy().Enter( self.profile )
> File "C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3650, in __call__
> return self.__r_call(*args, **kw)
> File "C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3670, in __r_call
> self.__hd, self.__ma)
> File "C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py", line 3585, in __call
> raise p
>faultType: <Fault SOAP-ENV:Client: No method Enter found>
