[AG-TECH] enter venue error
    Lloyd W. Belknap
    lwbelknap at lbl.gov
    Wed Jun  4 16:44:39 CDT 2003
Thomas, could you check the server again? It appears to be hung.
At 10:03 PM -0500 6/3/03, Thomas Uram wrote:
>The venue server was hung on a known, but yet unresolved issue.  I
>have restarted it, so your clients should work fine now.
>Tom
>Mike Elmore wrote:
>>I am experiencing the same problem Lisa is experiencing in her email.  I
>>was able to get into the lobby the first time.  I then went to the
>>additional room lobby, then I couldn't go into any more rooms.  I got
>>the same error.
>>Mike
>>Title: Enter Venue Error
>>I am trying to connect to the default venue using AG 2.0, but I keep
>>receiving a message that an error occurred.  The message says: "You have
>>not entered the venue located at
>>https://vv2.mcs.anl.gov:9000/Venues/default.  An error occurred.
>>Please, try again.  Note: Read VenueClient.log for more detailed
>>information"
>>The text from VenueClient.log from the error on is shown below.  Does
>>anyone know what is wrong/how to fix this?  Thanks!
>>VenueClient.log:
>>06/03/03 14:43:55 1236 AG.Types venueclient.py:775 ERROR
>>bin.VenueClient::EnterVenue failed
>>Traceback (most recent call last):
>>  File "C:\agapps\AGTk 2.0\VenueClient.py", line 676, in EnterVenue
>>    warningString = VenueClient.EnterVenue( self, URL )
>>  File "C:\agapps\Python22\Lib\site-packages\AccessGrid\VenueClient.py",
>>line 264, in EnterVenue
>>    (venueState, self.privateId, streamDescList ) = Client.Handle( URL
>>).get_proxy().Enter( self.profile )
>>  File
>>"C:\agapps\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AG
>>GSISOAP.py",
>>line 3650, in __call__
>>    return self.__r_call(*args, **kw)
>>  File
>>GSISOAP.py",
>>line 3670, in __r_call
>>    self.__hd, self.__ma)
>>  File
>>GSISOAP.py",
>>line 3570, in __call
>>    config = self.config)
>>  File
>>"C:\agapps\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py",
>>line 184, in call
>>    r.endheaders()
>>  File "C:\agapps\Python22\lib\httplib.py", line 695, in endheaders
>>    self._send_output()
>>  File "C:\agapps\Python22\lib\httplib.py", line 581, in _send_output
>>    self.send(msg)
>>  File "C:\agapps\Python22\lib\httplib.py", line 548, in send
>>    self.connect()
>>  File "C:\agapps\Python22\Lib\site-packages\pyGlobus\io.py", line 1079,
>>in connect
>>    self.sock.connect(self.host, self.port, self.io_attr)
>>  File "C:\agapps\Python22\Lib\site-packages\pyGlobus\io.py", line 663,
>>in connect
>>    raise ex
>>GSITCPSocketException: a system call failed (Invalid argument)
