[AG-TECH] Small Scale Node
    Allan Spale
    aspale at evl.uic.edu
    Thu Jul 31 21:33:00 CDT 2003
Monika,
AP-Ware does use a lot of CPU cycles and as much as is available.  This is
primarily because the software polls the Gentner quite frequently.  I
have noticed above 90% when the software connects to the Gentner.
However, this was one anomoly.  If my memory serves me correctly, if
you were monitoring mic levels, the CPU usage actually drops
significantly (not sure why, someone can verify this).
For you or anyone that is interested, the polling process can have its
priority lowered.  In Windows 2000, open up the Task Manager and go to the
list of processes.  Find the process named APServe.exe.  This is the
process that does the polling of the Gentner device.  The AP-Ware user
interface has the process name of APWare.exe.  Right-click on the
APServe.exe process and select something like Set Priority (not in front
of that PC now), and select Low.  When the warning box comes up, click ok.
This will make a noticable difference in CPU usage, and the polling
process will relinquish its CPU cycles to other programs.
Allan
EVL at UIC
Research Assistant
On Thu, 31 Jul 2003, Rabarison Monika Klara wrote:
> On our smaller node I have both audio and video on one linux machine
> running both AG1.0 and AG 2.0 without problem so far. However the Display is on win 2000 with one
> projector and the Control is on win 98. I have noticed that the Gentner on the control
> machine consumes a lot of resources.
> Budget wise I don't know much about :)
> Monika
> On Thu, 31 Jul 2003, Glover George wrote:
> > Hello all,
> > 	We've been using the Access Grid now for over and year and no
> > real complaints.  However, I was wondering if anyone can help us with
> > this.  We're looking at the possibility of building a small scale AGN
> > here at USM for another location on campus.  They do not need or want to
> > spend the type of budget required for a full scale room, with 2 or 3
> > projection screens.  We were wondering, does anyone have experience in
> > setting something small up, say between $10,000 and $15,000?  I've
> > noticed that it would be possible to run (in version 1 of AG) both the
> > audio and video on one linux machines (as we had to do when we lost the
> > motherboard in the audio machine), and be able to run both the control
> > and display machines on the same windows machine.  Now I haven't got too
> > far along with the personal type node that is on the site with the
> > version 2 software, because I don't have a signed signature, but I was
> > wondering.....
> > 1.  Since it feels like most of the setup revolves around the display,
> > what type of inexpensive display would work best, possibly one projector
> > if small enough, maybe a large monitor or flat screen, plasma display,
> > etc.
> > 2.  For a one or two camera setup, what would be the requirements in
> > hardware and software.  Is version 2 of the AG agile enough to be
> > configured in many different ways, is this even recommended?
> > 3.  Anything anyone can suggest will be much appreciated.
> > Thanks in advance.
> > Glover George
> > Systems Admin/Programmer
> > University of Southern Mississippi
> > Glover.george at usm.edu
> Monika Rabarison
> Systems Administrator
> Office of Information Technology/HPCVI
> Jackson State University
> Office:(601)979-5933
> SciVis Lab:(601)979-1061
> JSUvisNode:(601)979-1056
