[AG-TECH] Multiple Hauppauge cards
    Kabe VanderBaan
    kabev at labs.mot.com
    Wed Jul 30 13:09:54 CDT 2003
 > What does do the commands lspci and dmesg report as far as cards go?
lspci:
00:00.0 Host bridge: Intel Corp. 82815 815 Chipset Host Bridge and Memory Controller
Hub (rev 04)
00:02.0 VGA compatible controller: Intel Corp. 82815 CGC [Chipset Graphics
Controller] (rev 04)
00:1e.0 PCI bridge: Intel Corp. 82801BA/CA/DB PCI Bridge (rev 11)
00:1f.0 ISA bridge: Intel Corp. 82801BA ISA Bridge (LPC) (rev 11)
00:1f.1 IDE interface: Intel Corp. 82801BA IDE U100 (rev 11)
00:1f.2 USB Controller: Intel Corp. 82801BA/BAM USB (Hub #1) (rev 11)
00:1f.3 SMBus: Intel Corp. 82801BA/BAM SMBus (rev 11)
00:1f.4 USB Controller: Intel Corp. 82801BA/BAM USB (Hub #2) (rev 11)
00:1f.5 Multimedia audio controller: Intel Corp. 82801BA/BAM AC'97 Audio (rev 11)
01:07.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
01:07.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
01:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
01:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
01:0c.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
dmesg:
Linux version 2.4.20-8 (bhcompile at porky.devel.redhat.com) (gcc version 3.2.2 20030222
(Red Hat Linux 3.2.2-5)) #1 Thu Mar 13 17:54:28 EST 2003
BIOS-provided physical RAM map:
  BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
  BIOS-e820: 0000000000100000 - 000000000fdf7000 (usable)
  BIOS-e820: 000000000fdf7000 - 000000000fe16000 (ACPI data)
  BIOS-e820: 000000000fe16000 - 0000000010000000 (reserved)
  BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
  BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
  BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
253MB LOWMEM available.
On node 0 totalpages: 65015
zone(0): 4096 pages.
zone(1): 60919 pages.
zone(2): 0 pages.
Kernel command line: ro root=LABEL=/
Initializing CPU#0
Detected 996.783 MHz processor.
Console: colour VGA+ 80x25
Calibrating delay loop... 1985.74 BogoMIPS
Memory: 250968k/260060k available (1347k kernel code, 6680k reserved, 999k data, 132k
init, 0k highmem)
Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
Inode cache hash table entries: 16384 (order: 5, 131072 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 16384 (order: 4, 65536 bytes)
Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU:     After generic, caps: 0383fbff 00000000 00000000 00000000
CPU:             Common caps: 0383fbff 00000000 00000000 00000000
CPU: Intel Pentium III (Coppermine) stepping 0a
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.40 (20010327) Richard Gooch (rgooch at atnf.csiro.au)
mtrr: detected mtrr type: Intel
PCI: PCI BIOS revision 2.10 entry at 0xfbfee, last bus=1
PCI: Using configuration type 1
PCI: Probing PCI hardware
Transparent bridge - Intel Corp. 82801BA/CA/DB PCI Bridge
PCI: Using IRQ router PIIX [8086/2440] at 00:1f.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16)
Starting kswapd
VFS: Disk quotas vdquot_6.5.1
pty: 2048 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ
SERIAL_PCI ISAPNP enabled
ttyS0 at 0x03f8 (irq = 4) is a 16550A
ttyS1 at 0x02f8 (irq = 3) is a 16550A
Real Time Clock Driver v1.10e
Floppy drive(s): fd0 is 1.44M
FDC 0 is a National Semiconductor PC87306
NET4: Frame Diverter 0.46
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00beta-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH2: IDE controller at PCI slot 00:1f.1
ICH2: chipset revision 17
ICH2: not 100% native mode: will probe irqs later
     ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
     ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:pio
hda: WDC WD200BB-75CLB0, ATA DISK drive
hdb: IOMEGA ZIP 250 ATAPI, ATAPI FLOPPY drive
blk: queue c03c9f40, I/O limit 4095Mb (mask 0xffffffff)
hdc: SAMSUNG CD-ROM SC-148C, ATAPI CD/DVD-ROM drive
hdc: Disabling (U)DMA for SAMSUNG CD-ROM SC-148C
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hda: host protected area => 1
hda: 39102336 sectors (20020 MB) w/2048KiB Cache, CHS=2434/255/63, UDMA(100)
ide-floppy driver 0.99.newide
hdb: No disk in drive
hdb: 0kB, 0/64/32 CHS, 4096 kBps, 512 sector size, 2941 rpm
Partition check:
  hda: hda1 hda2 hda3
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 32768)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 146k freed
VFS: Mounted root (ext2 filesystem).
Journalled Block Device driver loaded
hda: dma_intr: status=0x51 { DriveReady SeekComplete Error }
hda: dma_intr: error=0x84 { DriveStatusError BadCRC }
hdb: DMA disabled
ide0: reset: success
kjournald starting.  Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Freeing unused kernel memory: 132k freed
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-uhci.c: $Revision: 1.275 $ time 17:59:01 Mar 13 2003
usb-uhci.c: High bandwidth mode enabled
PCI: Found IRQ 11 for device 00:1f.2
PCI: Setting latency timer of device 00:1f.2 to 64
usb-uhci.c: USB UHCI at I/O 0xff80, IRQ 11
usb-uhci.c: Detected 2 ports
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
PCI: Found IRQ 11 for device 00:1f.4
PCI: Setting latency timer of device 00:1f.4 to 64
usb-uhci.c: USB UHCI at I/O 0xff60, IRQ 11
usb.c: new USB bus registered, assigned bus number 2
usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
usb.c: registered new driver hiddev
hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech at suse.cz>
hid-core.c: USB HID support drivers
mice: PS/2 mouse device common for all mice
EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,2), internal journal
Adding Swap: 522104k swap-space (priority -1)
EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,1), internal journal
parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
parport0: irq 7 detected
ip_tables: (C) 2000-2002 Netfilter core team
PCI: Found IRQ 11 for device 01:0c.0
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
See Documentation/networking/vortex.txt
01:0c.0: 3Com PCI 3c905C Tornado at 0xec80. Vers LK1.1.18-ac
  00:06:5b:50:a3:fa, IRQ 11
   product code 0000 rev 00.3 date 06-10-00
   Internal config register is 1800000, transceivers 0xa.
   8K byte-wide RAM 5:3 Rx:Tx split, autoselect/Autonegotiate interface.
   MII transceiver found at address 24, status 782d.
   Enabling bus-master transmits and whole-frame receives.
01:0c.0: scatter/gather enabled. h/w checksums enabled
divert: allocating divert_blk for eth0
lp0: using parport0 (polling).
lp0: console ready
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 201M
agpgart: agpgart: Detected an Intel i815 Chipset.
agpgart: AGP aperture is 64M @ 0xf4000000
memory : ce1fdf00
memory : 00000000
memory : ce1fdf80
hdc: ATAPI 48X CD-ROM drive, 128kB Cache
Uniform CD-ROM driver Revision: 3.12
ide-floppy: hdb: I/O error, pc =  0, key =  2, asc = 3a, ascq =  0
ide-floppy: hdb: I/O error, pc = 1b, key =  2, asc = 3a, ascq =  0
ide-floppy: hdb: I/O error, pc = 1e, key =  2, asc = 3a, ascq =  0
cdrom: This disc doesn't have any tracks I recognize!
Linux video capture interface: v1.00
i2c-core.o: i2c core module
i2c-algo-bit.o: i2c bit algorithm module
bttv: driver version 0.7.96 loaded
bttv: using 4 buffers with 2080k (8320k total) for capture
bttv: Host bridge is Intel Corp. 82815 815 Chipset Host Bridge and Memory Controller Hub
bttv: Bt8xx card found (0).
PCI: Found IRQ 9 for device 01:07.0
PCI: Sharing IRQ 9 with 00:02.0
PCI: Sharing IRQ 9 with 01:07.1
bttv0: Bt878 (rev 17) at 01:07.0, irq: 9, latency: 64, mmio: 0xf8003000
bttv0: detected: Hauppauge WinTV [card=10], PCI subsystem ID is 0070:13eb
bttv0: using: BT878(Hauppauge (bt878)) [card=10,autodetected]
bttv0: Hauppauge/Voodoo msp34xx: reset line init [5]
i2c-core.o: adapter bt848 #0 registered as adapter 0.
bttv0: Hauppauge eeprom: model=44371, tuner=Philips FM1236 (2), radio=yes
bttv0: using tuner=2
bttv0: i2c: checking for MSP34xx @ 0x80... found
i2c-core.o: driver i2c msp3400 driver registered.
msp34xx: init: chip=MSP3435G-B6, has NICAM support
msp3410: daemon started
bttv0: i2c attach [client=MSP3435G-B6,ok]
i2c-core.o: client [MSP3435G-B6] registered to adapter [bt848 #0](pos. 0).
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
tvaudio: TV audio decoder + audio/video mux driver
tvaudio: known chips:
tda9840,tda9873h,tda9874h/a,tda9850,tda9855,tea6300,tea6420,tda8425,pic16c54 (PV951)
i2c-core.o: driver generic i2c audio driver registered.
i2c-core.o: driver i2c TV tuner driver registered.
tuner: probing bt848 #0 i2c adapter [id=0x10005]
tuner: chip found @ 0xc2
bttv0: i2c attach [client=Philips NTSC (FI1236 and compati,ok]
i2c-core.o: client [Philips NTSC (FI1236 and compati] registered to adapter [bt848
#0](pos. 1).
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: registered device radio0
bttv: Bt8xx card found (1).
PCI: Found IRQ 10 for device 01:08.0
PCI: Sharing IRQ 10 with 00:1f.3
PCI: Sharing IRQ 10 with 00:1f.5
PCI: Sharing IRQ 10 with 01:08.1
bttv1: Bt878 (rev 17) at 01:08.0, irq: 10, latency: 64, mmio: 0xf8001000
bttv1: detected: Hauppauge WinTV [card=10], PCI subsystem ID is 0070:13eb
bttv1: using: BT878(Hauppauge (bt878)) [card=10,autodetected]
bttv1: Hauppauge/Voodoo msp34xx: reset line init [5]
bttv1: i2c attach [client=MSP3435G-B6,ok]
i2c-core.o: client [MSP3435G-B6] registered to adapter [bt848 #1](pos. 0).
tuner: probing bt848 #1 i2c adapter [id=0x10005]
bttv1: i2c attach [client=(unset),ok]
i2c-core.o: client [(unset)] registered to adapter [bt848 #1](pos. 1).
i2c-core.o: adapter bt848 #1 registered as adapter 1.
bttv1: Hauppauge eeprom: model=44371, tuner=Philips FM1236 (2), radio=yes
bttv1: using tuner=2
bttv1: i2c: checking for MSP34xx @ 0x80... found
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: registered device radio1
bttv0: PLL: 28636363 => 35468950 ... ok
bttv1: PLL: 28636363 => 35468950 ... ok
bttv1: PLL: switching off
bttv0: PLL: switching off
> On Wed, 2003-07-30 at 11:34, Kabe VanderBaan wrote:
>>All,
>>I am using a Dell Optiplex GX150 and trying to install 4 hauppauge cards under Linux.
>>   However, only 2 cards are being recognized.
>>I already updated the Bios to the most recent version (A10).
>>The archives on AG-TECH seem to all point to upgrading the BIOS.  But this did not
>>solve my problem.
>>1) Is anyone successfully using a GX150 under Linux w/more than 2 Cards? (Hauppauge
>>or Osprey, etc).
>>2) Does anyone have any ideas/pointers on how to solve this problem?
>>I am trying to install the AG 1.0 software to do some testing.
>>Steps:
>>1) install redhat 9.0
>>2) install ag-tech rpms from
>>http://ag-tech.mcs.anl.gov/reldb/repository/releases/agib/snapshots/snap-006/
>>3) execute /usr/local/ag/bin/video-config
>>(video-config only recognizes 2 cards being installed.
>>Thanks,
>>Kabe
Kabe VanderBaan, Senior Research Engineer
Networks and Infrastructure Research, Motorola Labs
Phone: 847-576-1832
Cell: 847-980-4100
http://internet2.motlabs.com/agnode/
http://internet2.motlabs.com/ipaq/
