[AG-TECH] RH7.2 AG2.0 problem
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Jul 21 17:21:46 CDT 2003
Both of these problems are due to a pre-release version installed on the
Linux box.  The 2.0 install does not automatically remove pre-release
RPMs, so you will have to manually remove them before installing the 2.0
rpms.
Tom
Todd Zimmerman wrote:
>Hi all,
>I'm trying to get our room node working under AG2.0 and am having a few
>issues with the Linux side.  The Windows side seems to be working fine.
>I've tried to run the Linux side as either a stand-alone node or as part of
>the room node - but can't get it working either way.
>When trying to run the Linux box in stand-alone mode:
>I've basically followed the instructions at
>http://hpcnc.cpe.ku.ac.th/moin/InstallingAccessGrid to try to get the node
>running.
>All seems to work fine.  I start the AGNodeService and the AGServiceManager &
>start the VenueClient.  Once up and running, I can start the Node Manager and
>add the serviceManager & services, save the setup etc and connect to the
>VenueServer.  Again, at this point, all is still well.  However, when I
>attempt to change rooms the VenueClient hangs with the following output in
>the debug window:
>[Debug] 11:15:34 AM: VenueClient::GoToNewVenue: after enter venue
>https://vv2.mcs.anl.gov:9000/Venues/default
>[Debug] 11:15:34 AM: Set history url: None
>Traceback (most recent call last):
>  File "/usr/lib/python2.2/site-packages/AccessGrid/VenueClientUIClasses.py",
>line 1162, in onClick
>    self.parent.GoToNewVenue(event)
>line 1084, in GoToNewVenue
>    self.app.GoToNewVenue(description.uri)
>  File "/usr/bin/VenueClient.py", line 671, in GoToNewVenue
>    self.EnterVenue(venueUri)
>  File "/usr/bin/VenueClient.py", line 484, in EnterVenue
>    VenueClient.EnterVenue( self, URL )
>  File "/usr/lib/python2.2/site-packages/AccessGrid/VenueClient.py", line
>195, in EnterVenue
>    self.ExitVenue()
>  File "/usr/bin/VenueClient.py", line 605, in ExitVenue
>    VenueClient.ExitVenue(self)
>355, in ExitVenue
>    self.venueProxy.Exit( self.privateId )
>  File
>"/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py",
>line 3650, in __call__
>    return self.__r_call(*args, **kw)
>  File
>line 3670, in __r_call
>    self.__hd, self.__ma)
>  File
>line 3585, in __call
>    raise p
>AccessGrid.hosting.pyGlobus.AGGSISOAP.faultType: <Fault
>AccessGrid.Venue.ClientNotFound: ClientNotFound
>[Debug] 11:16:07 AM: VenueClient::GoToNewVenue: Go to new venue
>https://vv2.mcs.anl.gov:9000/Venues/000000f5569d4ffc008c00dd000b00377de
>[Debug] 11:16:07 AM: VenueClient::GoToNewVenue: Is this a server
>[Debug] 11:16:07 AM: VenueClient::GoToNewVenue: venue url:
>[Debug] 11:16:07 AM: VenueClient::GoToNewVenue: the handler is valid
>[Debug] 11:16:07 AM: EVENT- Enter venue with url:
>[Debug] 11:16:07 AM: clean up frame and exit
>[Debug] 11:16:07 AM: Cleanup frame, save data, and exit venue
>>From there it hangs and I have to manually go in and kill the processes.
>Now, when attempting to run the node as part of the room node, I get a
>different error; however, I'm sure they are interrelated.  On the Linux box,
>I start up the AGServiceManager.py and start the NodeService and
>ServiceManager on the Windows side.  Once within the NodeManager I add the
>Linuxbox ServiceManager to the list (all ok so far) and start adding
>VideoProducer services.  It actually finds the three capture cards on the
>Linux box; however, when it adds them, it complains:
>Exception in AddService :  AccessGrid.hosting.pyGlobus.AGGSISOAP.faultType
><Fault exceptions.AttributeError: AttributeError: 'str' object has no
>attribute 'uri'
>And on the Linux side AGServiceManager debug prints out (with our
>computername removed....):
>Running Service; options: /usr/bin/python2.2
>['/tmp/local_services/VideoProducerService.py', 60348]
>Trying client handle
>Wait another sec for service to boot; elapsedTime =  0
>Starting server at https://xxxdeletedxxx:60348/Service
>  File "/tmp/local_services/VideoProducerService.py", line 205, in ?
>    while server.IsRunning():
>AttributeError: Server instance has no attribute 'IsRunning'
>* * Service handle is valid !
>I'm sure these two issues are related - and I'm wondering if it is
>conflicting with a pre RC install of AG2.0 - I thought I had removed all
>remnents but one can never be sure.
>Any help would be appreciated!!!
>Thanks in advance,
>Todd Zimmerman
>Research Assistant - NewMIC
>New Media Innovation Centre
>Ph: 604.806.5100
>todd.zimmerman at newmic.com
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20030721/17224961/attachment.htm>
