[AG-TECH] 'Yellow' flash in vic
Darin Oman
darin at ucar.edu
Thu Jul 10 15:43:57 CDT 2003
I noticed this when we were running the AG 2.0 RC1. We were using our Display (WinXP) machine as a single-machine node and I was using 2 Osprey 100 capture cards. The flash would happen at the same time on both video caps. I haven't noticed it since we:
1. Upgraded to AG 2.0 full release.
2. Removed one of the cards.
I know we were having multicast problems for a while, but I'm not sure if the yellow flashes were happening at the same time. We never had the yellow flash on any of our WinTV cards, which were used on our Video (Red Hat 7.3) machine during the AG 1.x days and recently on the same machine running AG 2.0.
I know this probably doesn't help much, but hopefully you'll be able to find some common ground. If you figure out the problem, I'd like to know what it was.
Good luck!
Darin
On 7/10/2003 at 1:07 PM Randy Groves wrote:
>I've noticed recently that some of my machines (I thought it was only on
>one that has a single 2.4GHz Xeon, but now I'm seeing it on a dual), that
>there is sometimes a yellow flash that occurs on some of the cameras.
>I've
>not done any tracking of type, graphics card, etc., but I'm wondering if
>this is a known occurrence, and if there is any info as to whether it is
>overloaded CPU, lack of memory, insufficient graphics card or none of the
>above.
>And if there's a FAQ that I can peruse - just whack me up-side the head
>with it!
>Thanks!!
>-randy
